Question about Samsung CLP 300 Laser Printer
Can't seem to print the colour red
My Samsung CLP-300 can't seem to print the colour red. I tried printing out the test page and the window logo was blue, green and yellow. The printer hasn't indicated that the red toner has run out, but I changed to a new one today anyway. The same problem is still happening.
Can anyone please help?????
Thanks in advance.
  • cindy12490 Jan 22, 2009
    If you don't mind, can you please tell me how to do the above? Or perhaps point me to a particularly webpage??
    Thank you.
Have you tried updating the printer drivers or cleaning the printer heads on printer properties
Posted on Jan 22, 2009
Samsung CLP-310 Colour laser doesn't print properly
This is not a driver or Windows issue, has the ink cartridges been changed recently, it sounds like the the paper is not being magnetically charged before the ink, unplug the power cord for 30 sec plug back in and try printing again
Nov 07, 2013 | Samsung CLP 300 Laser Printer
Faded printing
Clean the toner roller blades
You Tube Video
Shows you the problem & how to fix it. There's a metal blade on the edge of each toner roller which can get clogged with small bits of toner & prevent even distribution. Clean the blade with a lolly stick & put it back together.
I tried this with CLP 320 cartridge - same principle but can be messy because the cartridge is full of toner powder.
Jun 04, 2012 | Samsung CLP 300 Laser Printer
Samsung CLP-300 refuses to acknowledge new toner. The toner is brand new from Samsung. Test page shows the colour being used perfectly in the Samsung logo. The light just continues to flash and the...
you may press and hold the button for 5sec and let go to print the supplier info.
If it still show @ 0% you may want to check with the shop you purchase to get an 1 to 1 replace.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 22, 2009 | Samsung CLP 315 Laser Printer
Can't print just black when out of color with Samsung CLP-300
its not possible till you get that rec colour refilled in your colour cartridge or replace the colour you cannot print black as the printer is not been able to end its cycle as the cycle is getting break at the colour cartridge.its very common problem faced by many users but no other option except replacing or refilling the cartridge.
Dec 14, 2008 | Samsung CLP 300 Laser Printer
Samsung clp-300 printing
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Samsung CLP 300 Laser Printer
Not printing correctly across the whole page
ok....once just completely remove the toner and its mechanisms and clean then with iso-profile alcohol and re assemble them after the reassembling
Dec 28, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
125 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
