Question about LG 42LB5D 42 in. LCD Television
Black screen there is sound and you can here it change thru the inputs but the screen is all black
  • LG Master
  • 8,617 Answers
The inverter board is bad and needs replacement. You can get the inverter board from www.tvrepairworld.com
Posted on Jan 11, 2013
Blank screen
Any error message about inputs? Maybe that clicking sound happens when iit connects to the selected input, but nothing is connected. Can you scroll thru all the inputs? If so, turn on any devices connected to the JVC and scroll thru each input to find the one you're looking for.
Jul 11, 2013 | JVC Audio Players & Recorders
No picture
interesting.have you tried playing a dvd thru a connected dvd player thru the 457. I would be curious to know if a different video source causes the same black and white pattern. try that and let me know.
Sep 10, 2007 | Yamaha RX-V457 Receiver
Technika TV with blank screen and no sound
Go to menu, settings and select factory default settings. Most probably the input selection has got changed.
Aug 13, 2012 | Televison & Video
Rca tv... screen is black when you turn it on but it will show the Menu and let you go thru the menu... It also says tv is muted and wont let you turn the tv up
In the menu see if you change the input selection to something you know is on (a cable box, DVD player) and make sure that is the input picked.
Dec 25, 2010 | RCA Televison & Video
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Screen goes black after powering up sound is just fine.
The backlight video board inverter it dead,need a new one.
Oct 03, 2009 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Can not change "Device" input, no sound control,no remote control
I unplugged the manual switch electrical connection. Everything works just fine with the remote.
Not sure what is wrong with the switches just yet, but suspect a resistor problem. I have checked all voltages and have 5.04 v feeding the switch assembly on what I feel are the correct circuits
(5v, ksco, ksc1, man/reset). I have no voltage on the ground circuit with the board plugged in, so the ground circuit should be ok. I have tested all switches with ohmmeter, all switches work. I suspect a resistor problem as I have one with no voltage drop and one resistor with no voltage pass-thru. Would need a wiring schematic with values to pinpoint better.
May 16, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Completely black screen but has sound.
you probabily need to change the input, find the input button, when you hit it you should get a box on the screen, with inputs, highlight diferent ones and hit select- untill you get pick back, thats what my sugestion would be
Jan 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
LG 42LB5D 42 in. LCD Television Logo
60 people viewed this question
Computer Repairing
Computer Repairing
