Question about Intel Motherboard
Physical memory dump blue sreen
Fatal error
  • Alex Smallwood
    Alex Smallwood May 11, 2010
    Ah , the infamous Blue Screen Of Death , as its commonly called
    Look for the text saying STOP followed by a series of letters and numbers. Write this down
    google the error code for a solution
    Also , if you have recently added any hardware or software to your computer , this may be causing the error -try removing any recently installed software or hardware and see if the problem persists
  • 81 Answers
This is error message is primarily related to the physical memory of your system is not working properly.. or else it might be a issue with the slot for the memory on your computer.... i would recommend you to contact a local guy or else you can also try to reinstall your windows on the system...
Posted on Jan 22, 2009
After installing the new windows this problem will be resolved but need some more solution without installin the windows
Posted on Mar 28, 2009
Posted on Feb 20, 2009
Error code after running diagonistics
If you run Advanced System Care that will repair your errors, if repairable.
Looks like a fatal error though. Back up your data,NOW!
Nov 17, 2013 | Dell Xps 15 Laptop Computer (Intel CORE I5...
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
My toshiba satellite M55-S135 is showing a blue screen with "physical memory dump complete" & to contact tech support. Basically, wanted to ask if my laptop is crashed...
Hi:
Crashed is a generic term, and the physical memory dump error is a windows based error that could be a bad memory stick, or a corruption in windows. If you have 2 sticks of memory in your laptop, a cheap and easy way to troubleshoot this would be to remove one stick, then the other,to see if one stick removed stops the crash. If it does, then you have solved the problem, and if it doesnt' then you have a corrupt software issue.
Hope you get a cheap fix!
Jan 18, 2010 | Toshiba Satellite M55-S135 Notebook
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
It will constantly doin a physical dump of memory
Physical memmory dump( blue death) as it is called happens due to various reasons, which are related to harrdware failure or overloading of hardware. it can happen if the ram, cpu or the harddrive have some problem in connectgionn with the motherboard- try cleaning the sockets of the RAM and trying agin. the blue scrreens means windows went through a critical error<which is hardware related>. if it happens some times its nothing to worry about but if it happens often then you need to get your hardware checked by soem professional as it be corrupted somehow.
Aug 08, 2009 | IBM ThinkPad T20 2647 Notebook
Memory dump
There are essentially two major causes of the physical memory dump screen: Running way to many programs at once, errors in the Windows registry.The first cause can be fixed rather easily. Simply run fewer programs or purchase additional RAM or processor upgrades. Your computer is running past its specified limits. But keep in mind the blue screen of
death should happen very infrequently. If you see the physical memory dump blue screen more often then the problem is errors in the Windows registry.This is a more abit of a harder problem to deal with. The registry is the most important component of your computer. The registry contains settings and information to run all software and hardware on the computers. When there are errors in the registry it disrupts the computers ability to communicate. When the system cannot compute, it freezes up and displays the Windows blue screen.
I found a registry cleaner that is free and works rather well. It is named cCleaner, has been around for some time and did I mention FREE...Download it from thelink below run it should clean up your registry...where good men fear to tread.
http://www.ccleaner.com/ccleaner-20
good luck, please leave a rating...thank you
May 04, 2009 | Intel Computers & Internet
Blue screen physical dump error
Hi
They virtual memory should have been exceeded the limit.
Step 1:
Power Drain:
1.Disconnect all the cabled from laptop, including Memory card and wireless card(wi-fi)
2.Take out the batteries
3.Press and hold the ON button for 30 seconds
4.Put the batteries in and boot the laptop.
if its does not works
Step 2:
Upgrade the RAM memory of the Laptop
Thanks
Riz
Jan 13, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Blue screen
hi daget200;
can you post the exact error message? its located at the top few lines so that we will know whats causing it. have you inserted a new hardware recently? when does the error occur? intermittent? does it happen when you are playing games or something? pls expound. thanks
Jun 07, 2008 | Computers & Internet
Blue srren fatal error
you was probably installing updates in the background and youve interrupted install and shutdown improperly (reason)
turn on pc and press f 8. if youve never done this before;as soon as you see anything at startup keep pressing f 8 youll still get to the place you want to be.select start up using last known good configuration.
Mar 02, 2008 | HP Pavilion dv6000z Notebook
Memory dumpping
That is usually called a fatal error. It's not really fatal but you need to fix it. Download ccleaner and regscrub xp both for free and run them to clean your system up. It should run much quicker after that.
Oct 21, 2007 | Logitech Keyboard
Intel Motherboard Logo
459 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
