Question about Saws
Where can i get a wiring diagram to install the wires in a balfour motor on a wells band saw F-15
  • 3 more comments
  • Ronnie Jan 14, 2013
    thats where i run into the problem, i don't have any manuals at all on this machine, was hoping somebody had some info that they could email me, any info would be greatly appreciated
    WF Wells F-15 all ID plates are missing, one of my guys let a piece of pipe roll off and pulled the wires out of the junction box on the motor, the Balfour motor has a diagram but only to wire high or low voltage,
  • Jack Faire Jan 14, 2013
    I think you should give Wells bandsaw a call to that they can help you out better and they can also send you over a wiring diagram .
  • Ronnie Jan 15, 2013
    yes sir, thanks, i finally got the company that had it before me look through their info and got me a serial# so I'll be giving Wells a call in the morning,
  • Jack Faire Jan 15, 2013
    Perfect. Hope everything will be fine with the issues you're having with your bandsaw.
    Sergeant:
  • 468 Answers
Have you check your manual? I believe the wiring diagram can be seen in the manual.
Jack
www.bandsawblog.com
Posted on Jan 14, 2013
danny_murray
  • 55 Answers
SOURCE: wiring diagram for jet bansaw hvbs-7mw
Here is a link to the manual hope it will help you out
http://industrial.jettools.com/Products.aspx?Part=414459
Posted on Dec 05, 2008
vinzen
  • 217 Answers
SOURCE: My Delta band saw motor is having issues. I was
I would bet it's the Motor Brushes.They are locaded on the housing of the saw, accesed by unscrewing the plug.The brushes are replaceable and your saw will be fixed.Where to buy replacents could be an issue,Check manufacturer or search power tool replacement motor brushes.If stuck you can try to unscrew the plug the brush is at the bottom engaging the motor armerure,there shoud be a spring keeping contact.Inspect brush condition it looks like a carbon block worn to the curve of the motor.Go online do a search on how electric motors work you'll see exactly what I'm explaining.Cheap part easy fix.Good Luck.
Posted on Sep 05, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a 110v/220v motor on a band saw It is set
have you looked on the inside of the cover, usually they have a schematic there. If not give me the model and brand and I will try and find the information you need.
Posted on Jan 03, 2010
rowdy45176
  • 2176 Answers
SOURCE: I need a wiring diagram for Milwaukee 6230 band
go to "milwaukeetool.com" and with your model and serial (just the first few number) you can download a wiring schematic that is in complete detail for this tool. Let me know if you need more assistance.
Posted on Mar 16, 2011
falspet
  • 438 Answers
SOURCE: band saw motor won't start just hums
replace the start capacitor located on the motor housing these are brush-less motors and incorporate a capacitor or start or centrifugal switch and both are easily replaced and quite inexpensive
Posted on Apr 05, 2012
How do the wires run to the motor of a delta
I am not familiar with your band saw, I suggest you download a manual or wiring diagram.
Oct 09, 2014 | Saws
Wiring behind on off switch
What's the brand and model of your band saw machine? Check out the website of the manufacturer of your band saw , you might be able to ask a manual/ wiring diagram from them. I have once downloaded a wiring diagram from bandsawmanuals.com for my old band saw. Hope that helps.
Nov 28, 2013 | Saws
Wiring assembly needed
What's the brand and model of your band saw ? Check out bandsawmanuals.com. They have free dowloadable
manuals and wiring diagram for most brands of band saw machine. You need to register to the site
first before you can download for a manual.
Nov 28, 2013 | Saws
Replacing switch on 9" task force band saw & need wiring diagram
I couldn't find a manual or wiring diagram available online. A 9" Ryobi band saw looks like the Task Force saw. You may check for it. However, the two saws may have different instructions for the wiring layout. Your best option is call Lowes or see a electrician. They should be able to help you with that.
Sep 04, 2013 | RTO 7 X 12 1HP Turn Pro Band Saw
Wiring diagram for 260A band saw
GO TO http://www.ereplacementparts.com/ FIND YOUR MODEL AND LOOK THE PART DIAGRAM
Dec 12, 2011 | Saws
I need a wiring diagram for Milwaukee 6230 band saw
Apr 06, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
14" Delta Bandsaw keeps tripping the internal motor breaker.
The first thing that I would check is the wiring to the saw. My guess is that the wire to the saw or the cord is not heavy enough.
As saw like that can pull a lot of amps. Probably 15 or more when working hard. What happens is that when the amp draw goes up and the cord is too light, the voltage drops which increases the amps. and starts a vicious cycle...
The one thing that finally gives is the internal overload in your motor.
Try running heavier wire or a heavier extension cord if you are using one.
#12 wire or a 12 wire cord would be minimum, if running over say 50 feet then you should be looking at #10 wire.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 29, 2009 | Delta Saws
I bought a craftsman 9" band saw from a neighbor and I need to hook up the switch to a SH cap to the motor. I am unsure of how to hook up the wire diagram? Please help. Antonio
there should be a wiring diagram in the motor case or inside the wiring junction box on the motor, and if like most 120 volt motors it will have 2 wires coming out of the motor case and a cover where the cap is covered / stored on the motor,just hook-up the 2 wires to the cap, either wire on either cap terminal is ok
Oct 11, 2009 | Garden
Saws Logo
51 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
