Can't Program Channels In Philips 32HF7544D/27 LCD TV
I have a Philips LCD TV Model number 32HF7544D/27,and I can't seem to get it to where I can program the channels.I have a Enseo HD1000 tuner that came with the TV.It is supose to have a NTSC tuner built into it,but I can't seem to get it to where I can get the channels to show up.In the manual it shows that you can get into the TV setup menu by pushing the F button on the RC2573GR remote,but the only menus I can get into is the standard menu by pushing menu on the standard remote,and the internal TV setup menu by putting the TV in ITV mode by punching in a code,and pushing M on the RC2573GR remote.The code for the regular remote doesn't work.In the regular menu under install all it does is scan channel 0,and show a bar going accross the screen showing the MHZ. counting up.I'm guessing it is HD "Air" mode looking for an HD antenna?In the regular comsumer mode setup it doesn't give me a choice of cable,or air.I talked to the Philips company commercial division,and they told me that some of the menus are missing,and that I needed to have the TV reflashed.They also said that the only people that have the tool is them.Is there a way to reset the TV without having it reflashed?All the other functions seem alright.Please let me know if any of you can help.Any help is greatly appreciated.Thank You very much!
Tyler
  • nikdaisy722 Mar 14, 2009
    Bought a 32" Philips without remote and am trying to program it with a universal emerson remote. Can't get more than NBC. Help!
  • Anonymous Apr 30, 2009
    no audio how to flash it
    Top Expert:
  • Televison & ... Master
  • 74,634 Answers
Firmware update is necessary. It is corrupted.
Posted on Apr 29, 2015
SOURCE: Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Posted on Sep 09, 2008
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
  • 22 Answers
SOURCE: can't get all my cable channels
what cable company do you have because you should have a cable box because only a cable box can scramble the frequency so you can get the channel you subscribe for
Posted on Dec 17, 2008
unsivilaudio
  • 25 Answers
SOURCE: Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
Posted on Dec 31, 2008
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
Do I need a converter box for philips tv model 32hf7544d 27?
If it has an analog tuner, yes. If digital tuner, no.
Mar 26, 2016 | Philips Televison & Video
Is a converter required in order to receive over the air?
Not normally on a CRT televisions which is already analogue as is the over air signal. Your antennae should come with a small connection box and then you connect a fly lead to the ***** in aerial socket on the back of the television.
Have a read of this.
http://overtheair.saveandreplay.com/
Channel Master Antenna Over the Air Television Free TV using an Over the...
Mar 26, 2016 | Televison & Video
I have a Phillips Tv That I have bought off of my employer (Hotel Industry) with the Model # 32HF7544D/27 and I'm unable to get it programmed to channel 73 which is what my Satalite company uses (
Hotel sets use a special remote with specific instructions--you need to get that remote and the instructions---hotel knows that..........
Apr 08, 2012 | Televison & Video
How do i get regular tv channels no cable or direct tv. I have a 32' magnavox model #32MF338B/F7
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
Nov 03, 2010 | Philips Magnavox 27MS343S 27" TV
Hi, I just bought an older model Philips Magnavox from a hotel(Model Number: TL7127C107 Chassis Number: 27B700-7562). The T.V. itself works fine but I can't access all my channels. I did a little research...
sorry, it wont go away, bet ya got it cheap huh(nothing intended by cheap) but the tv hotel mode is telling you that its a special tuner made for just hotels, the only way to get around this is if you can replace the hotel type tuner on the main-board with a normal type tuner, it'll cost more than you paid though.good luck,a friend of mine bought 12 of then at $25 each, boy he thought what a deal, now he's really crying and they didn't tell him,and they won't refund his money
Oct 17, 2009 | Philips Magnavox 27MS343S 27" TV
Cant get channels to program manual or auto
Try the STANDAR mode search, instead of AUTO mode, also try IRC mode, and HDR more, maybe thats why you dont get any channel...
Mar 19, 2009 | Olevia 227-S11 27 in. LCD TV
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
Channels have just changed.
It sounds like your tuner mode has been changed. To change this back to cable hit menu arrow down to install, then arrow down to tuner mode and change that to cable. That should take care of your problem, if not email me at evilteddybear42@yahoo.com.
Jason
Dec 20, 2008 | Philips 27PT5445 27" TV
Televison & Video Logo
1,918 people viewed this question
Top Televison & Video Experts
Electro Med Services...
