For Whirlpool wfw9050xw00, The four blue wires coming off the water level switch have come off the part 10239066. I'm afraid of putting them back in the wrong order.
Please check this link for tips to wire the water level controller, the pressure switch. click on :Pressure switch.
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
SOURCE: Whirlpool Duet GHW9400 Water Level Seems Too Low
Scott,
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
SOURCE: water still in tub water level light blinking
GO TO www.repairclinic.com AND LOOK FOR PART 541811 IT MAY BE CLOGGED AND NEEDS CLEANED OUT THIS IS A LINT CATCHER FOR WASHERS
SOURCE: Whirlpool wtw5300sq0 doesnt reach desired water
your level switch sensor needs to be replaced on the control panel
SOURCE: WATER WON'T GO INTO WASHER,
Yes, this sounds like a water level switch to me. Sorry I can't add more :->.
