Question about Hoover Vacuums
My hoover 2100 over heats when used for more than 15 mins. I have checked everything there is nothing broken or blocked and it not used much.
    Scholar:
  • 108 Answers
There's only 2 reasons that heat switch will trip.
1. Not enough air
2. Bad motor or heat switch.
I would check your filters and suction on the tools. There should be LOTS of suction at the tools on that unit. If there's not follow the air back until you find the plug. It might just be a really dirty filter or carpet powder or something along that line plugging the filter.
If the suction is not a problem it might just be defective and in that case if it's not very old go to hoovers website and find a service center location and have it fixed. They shouldn't charge you for the repair if it's still under warranty. You'll need your receipt for it though, so hope you kept that!
Good Luck!
The Vac Dr.
Posted on Jan 14, 2013
I was vacuuming and my hoover vacuum died
they have a thermal shut off on the motor so if it gets too hot it shuts down
can take up o 30 min to reset check all filters make sure nothing is blocking
Aug 15, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The vacuum turns off mid cleaning
you have to check the thermostat for any problems.if you find the thermostat with any blackouts or burns you have to replace iot
May 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Over heated hover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632385
Generic problem for all Vacuums
Over heated hover
Posted by blade123 on May 29, 2008
Hi there, I’ve got a upright Hoover and it cuts out after about 5 mins I think it’s over heated but if i leave it for 5 mins it works again but cuts of again how can i fix it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you my have a heat sensor, but as far as what you described you need to change both belts, the brushroll belt and the power drive belt as well and @ the same time. The average belt change is every 4 to 6 months on the vacuum. Does it stop completely or is it just the belt problem. Or #2 is the vacuum giving off a burning smell other than the belts and if it does it could be the motor. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Hoover carpet cleaner
Take the brush block out, is the shaft that goes up into the turbine there, or is it broken off. If gone, then replace the brush block. If there, then probably the turbine isn't working, this is what drives the brushs. It may be just clogged up, you can remove the turbine, take it apart and clean it out real good and put it back together. If it works, then you are set, if not, then it will have to be replaced.
Mar 24, 2008 | Vacuums
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
