Question about ViewSonic VX724 17" LCD Monitor
ViewSonic 10049 Keep on Flashing
ViewSonic 10049 green light flash after every 3-5 sec when connected to the PC and please help.......
  • polax11 Mar 07, 2009
    monitor flashes green but does not turn on. I have to unplug it several times before it comes on.
    Problem Solver:
  • 8 Answers
Check no pins on the monitor lead are bent or snapped off
Posted on Jan 22, 2009
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Black screen
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | ViewSonic VX910 19" LCD Monitor
Green light keeps flashing but no picture appears.
Check Signal cable, and refresh rate, resolution in safe mode
Nov 09, 2009 | ViewSonic VA703B LCD Monitor
Tv come on for 2-3 sec. then cuts off no pic. (power button/green light)
does the green light keep flashing or does the light go out right away?
Larry
Jul 05, 2009 | Mitsubishi WD-73833 73" HDTV
The lamp continues to flash red lights for power and lamp
I have the same problem as posted too, ordered 3 new lamps and they all still do the same thing. I`m starting to think its the projector that has a problem. Anyone got a solution other then keep buying new lamps and try getting it to work... I mean, after 3, how bad lucky can you be that they are all bad lamps...
Dec 04, 2008 | ViewSonic PJ500 Multimedia Projector
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Unit will not power on
Company said it was defective. Sent back for exchange.
May 30, 2008 | ViewSonic PJ501 Multimedia Projector
ViewSonic VX724 17" LCD Monitor Logo
216 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
