Question about Frigidaire Washing Machines
Frigidaire horizon 2000, how do i get to motor?
  • Frigidaire Master
  • 17,129 Answers
Check this link which demonstrates fully to get to the motor and remove the drum. Click on ; Drum removal
Posted on Jan 12, 2013
3 Suggested Answers
  • 6277 Answers
SOURCE: Is there a lint filter/catcher
Probably!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 26, 2011
  • 33 Answers
SOURCE: Where can i see the manual for the frigidaire
go to there web site put in info and the manual should come up then down load it
Posted on Apr 28, 2012
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Where can I buy motor control board for horizon treadmill T101
just run in the open air, it's much better to experience real life
Jan 06, 2015 | Horizon Exercise & Fitness
Dont know how to remove cabinet on frigidaire horizon 2000?
to remove the front panel on the washer you have to remove the 2 screws at the bottom of the panel then the panel will drop down out of the slip and groove hooks and you can remove panel
Oct 29, 2013 | Whirlpool LTE6234D Top Load Stacked...
The motor will not move
test voltage from output control board motor, for input voltage terminal motor, if there ARE not voltage, the control board is faulty.
see my personal TIPS for motor.
2) test the terminal voltage motor, if there ARE the motor is faulty.
3)loose the belt and try again if the motor is running the problem is the deck belt board, LUBE it.
God bless you356531a7-34d7-49c5-b4b2-83d2982da514.gifafae3425-f7ac-48a8-b373-2402f885bb57.jpg
Oct 15, 2013 | Horizon Fitness Horizon Motor T51...
Horizon T52 does not work
please see the video and lube too the rollers bearing.
test too the input voltage motor, if there are voltage the motor need repair. see my personal TIPS for motor help, see the b.diagram
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Happy New Year. God bless you
Dec 31, 2012 | Horizon Fitness Exercise & Fitness
Where can i see the manual for the frigidaire horizon 2000 washer?
Apr 28, 2012 | Frigidaire Washing Machines
Is there a lint filter/catcher on a Frigidaire Horizon 2000 washing machine?
Probably!
John C
Aug 26, 2011 | Frigidaire Washing Machines
How do I calibrate my horizon t102. I turn it on and the level motor continues to run, the treadmill motor wont come on. I think it is a level sensor that is bad. Where is that located
The "level sensor" is built into the elevation motor assembly, which is a 10kohm potentiometer. What year treadmill? If the elevation motor assy has a small connector with an orange, blue and brown wire set, you can use an ohm meter to read this pot on these leads. It sounds like a loose cable upper to lower, or possibly a faulty motor control bd which controls the elevation. Unplug tread before looking around..
Oct 20, 2010 | Horizon Fitness Horizon T102 Treadmill ...
Horizon treadmill T90 won't start number reads 5105-04
touch a 9 volt battery to the motor wires and see if the motor moves.
if so, it's good and the board is bad.
We are a authorized service center for Horizon you can contact us @ www.nashsfitness.com
Aug 09, 2009 | Exercise & Fitness
Washing Machines Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
