Question about Kenwood eXcelon KDC-X979 CD Player
Faceplate stuck i just installed my deck and the faceplate won't open out. it moves back and forth a tiny bit when i hit the outside button but thats it.
    New Friend:
  • 83 Answers
Did you connect the battery wire to a constant 12+ ?
Posted on Jul 05, 2007
My key won't go into ignition on my 2007 jetta
Try moving wheel back and forth while putting key in. Or if thats not it, take a screw driver flathead and try to turn ignition both ways just a bit. Sometimes those key cylinders dont go back into the open key position. Try that as you are moving the whhel as well. but my car does the same thing in the cold, and a screw driver seems to do it every time. Good luck let me know how you make out. PS Im guessing that ther is not something stuck inside ignition?? Good luck
Jan 08, 2013 | Cars & Trucks
Burned CD with no label is stuck in my car stereo Pioneer model deh-p9200r. It plays fine, but how can I get the CD out?
When you remove the faceplate you will see a tiny small hole in the deck. Insert an open paperclip to remove the CD. PLEASE let me know if this helps
Jan 19, 2011 | Pioneer DEH-P9200R CD Player
Nothing works plese help !!!!
try the menu button , holding the fm/am button basically it is waiting for you to hit the security code correctly
Apr 10, 2009 | Kenwood KDC-519 CD Player
2003 Jeep Liberty Electric Mirrors only move a tiny bit then stop
it sounds like the switch is going bad in the mirrro switch on the driver door should be able to get on at any dealer it should be any fix
Jan 25, 2009 | 1999 Jeep Grand Cherokee
Face plate on KDC-MP528 kenwood deck wont open
if you have checked all of your wiring and fuses and already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Dec 16, 2008 | Kenwood KDC-MP528 CD Player
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Faceplate problems
I have the same deck and a very similar problem. Mine was stuck in the out position and would beep and move a little but there was no lights or music. I called Alpine and they told me that sometimes the inner sleeve around the deck will pinch the unit a little. I took my unit out of the dash and sure enough the plastic face plate came loose and moved about 1/32 of an inch when I slide it back in place and turned the power back on it worked perfectly. Hope this helps.
May 15, 2008 | Alpine CDA-7897 CD Player
Won't turn on
My only other hypothesis is that, similar to my wife's Kenwood deck that has the MASK motorized faceplate, the flex cable that connects the moving faceplate portion to the main unit has started to crack and lose connection. After a few years of moving back and forth, folding and unfolding, this seems to be a pretty common thing. I was able to replace the flex cable on my wife's deck, but only because I stumbled across detailed instructions (with pictures!) and I got lucky with the replacement cable being in stock at a local repair shop. Your mileage may vary :)
Nov 24, 2007 | JVC Arsenal KD-AR3000 CD Player
Flip Down faceplate is stuck.
I have the same problem, and all my problem was is that one of the wheels were out of place. You can see these white gears at the bottom left and right. Just stick something in there and push it back in place. It should just snap back in.
Mar 16, 2007 | Dual XD-7500 CD Player
Kenwood eXcelon KDC-X979 CD Player Logo
126 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
