Question about HP iPAQ rx5915
HP iPAQ rx 5915 will not turn on
It will not turn on, except for when it is on a charger. Even then, it keeps restarting, not getting past the entrance screen
  • patriciacamp May 26, 2009
    No WLAN. Busy signal. Bluetooth works.
Seems like you have a problem with your charger.happened to me too.did you try charging the ipaq via the usb cable on your computer?
Posted on Apr 28, 2009
I need a charger for my hp ipaq but i don't know what series
In general, there's three types of charger you might need. Really ancient iPAqs used a round DC jack type charger, then there was a long time where all iPaqs used the same flat 22-pin connector. More recently, HP has moved to the same mini-USB plug used for a lot of mobile devices.
If you're really stuck, try http://www.ipaqrepair.co.uk/store.php?cat_id=25 and match your iPaq to the pictures.
Jan 12, 2010 | HP iPAQ 612C Smartphone
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your iPAQ in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
IPAQ hp Pocket PC wont turn on!?!!
Same Problem Here I In The Dark Here I've Treid All The Other Formus I Might End Up Getting A New Charger.
Sep 23, 2009 | Compaq iPAQ H3630 Pocket PC
I have an HP Ipaq h1940 pocket PC. It won't charge!
Charge the dead battery with other good battery for a while first.
Jul 29, 2009 | HP iPAQ H1945 Pocket PC
Ipaq rx-3115 stops at align screen after reset
This happened to me and i got so mad that i broke the screen. But that was a good idea because then i got a new screen and now it works fine. Just get another screen and it should work fine. or you can just get the digitizer part and swap out your LCD parts.
Feb 17, 2009 | HP iPAQ RX3115 Pocket PC
Ipaq rx-3115 stops at align screet after reset
Sounds like u need a replacement LCD
Easily found on ebay
Replacement screens usually come with instructions.
Please note u will need a hollow t8 or t9 tool to open the ipaq case.
Hp ipaq hw6915
Try a Reset....
Performing a Clean Reset will help
A clean reset clears all user-installed settings, programs, and data, and restores
your HP iPAQ to factory settings.
To perform a clean reset and return your HP iPAQ to factory settings:
1.Press and hold the Answer/Send, Power, and End Call buttons.
2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Thanks
Nov 03, 2008 | HP iPAQ hw6915 Smartphone
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
IPAQ turns itself on
Go to the ActiveSync options of your pocket pc and to go to Mobile Schedule and choose "Manually". I think it's set to sync automatically in a few minutes that's why it turns itself on.
Sep 11, 2005 | HP iPAQ HX2100 Pocket PC
HP iPAQ  rx5915 Logo
280 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
