Question about Gateway GT3072m Desktop Computer - 1009007 Disk Drive - 320GB
How to recover hard drive bad sectors without making any damage to the available data?
Run windows 98 on your machine and click on repair bad sectors.
Posted on Jan 11, 2013
How to fix damaged hdd's sectors ????????
From what I have read a sector can be recovered only from Defrag if that doesn't work I have been told they are dead and can't be fixed
Nov 18, 2014 | Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
How can i retreive my password without eraseing the data?
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Jul 26, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a toshiba 500GB portable external hardrive....it still has 50GB more space left...however when i tried to open it...it wont open and i cant see my files...the computer says that it cannot fix the...
You can recover data from portable hard drive with data recovery software.Tenorshare data recovery is one of the bests. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,bad section, virus attack etc.Download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
Jul 10, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
My HP Compaq Presario V2000 PC Notebook start and stay's on the windows xp splash screen. I have tried loading it in safe mode and last good config but none works.
Hi
Of course without seeing it I can't make an exact diagnosis. My first though is that you have a bad sector on the hard drive which keeps Windows from loading because the head can't recover data under the bad sector. Slave this hard drive to a good one and back up the data. Download a copy of hdtune.exe. You can confirm the status of the hard drive with this. If you find bad sectors - replace the drive
Jun 03, 2010 | HP Compaq Presario V2000 Notebook
Hard disc not working
yah its possible to recover the data from hdd.
just baught a recovery tool cd and recover your data
hdd may has a bad sectores .u run a bad sector recover soft ware .
May 02, 2009 | Computers & Internet
How can recover data from free agent desktop hdd
Well you should have gone in and marked the sectors that you think are bad, by formatting it odds are you wiped the data off it, you can try a low level recover but I dont think your going to find much. Sorry format means format.
Aug 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to remove bad sectors from hard disc
Bad sectors are usually the result of physical damage to the disk, so you're not going to be able to remove them easily. A full format *may* clear them, but I'd expect them to fail again.
If you run a scan disk it will mark them as bad so the OS shouldn't attempt to write to them again. It will also attempt to recover the data from the bad sector and copy it somewhere else on the drive.
Jan 02, 2008 | Computers & Internet
Hardisk pro
You cannot recover bad sectors. Your disc is damaged and the drive has removed the bad sectors from being writable. You need to replace your hard drive asap before it breaks entirely. You're going to lose all your remaining data on the disc if you do not back it up immediately. Good luck, Peter
Aug 06, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Gateway GT3072m Desktop Computer - 1009007 Disk Drive - 320GB Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
