Question about Dishwashers
Built in dishwasher not working
Siemens dishwasher S9VT1S is not pumping the water out. I have cleaned all the filters and run some cleaner through it but still no good. The same thing happened a week or so again and a tap on the bottom got it going but there is clearly a more serios problem.
    Scholar:
  • 93 Answers
There is more than likely an obstuction in the drain hose try blowing on the hose back into the machine second make sure the hose is not pinched anywhere ny another appliance.you could also check the chances are that there may also be something in the pump(impellar houseing) wich moves around stopping or restricting the waterflow pull the pump and check
Posted on Jan 22, 2009
There is always water left in the drain at the bottom of the dishwasher, which gets sprayed back on the dishes so now my glasses have material on them and it gets baked on in the dry cycle....
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jul 20, 2011 | Siemens SL85A705UC 24 in. Built-in...
My siemens dishwasher is not working, The pump that you hear in the begining of the cylce, is running (even when I open the door) but it will not go to the next cycle of filling with water. We did have our...
the control computer is bad. the relay on the control for the pump is stuck. if its less then 5 years old it should be under warrnty. look for your owner book. find the warrnty section. it should have a service number to call.
Jan 10, 2011 | Siemens SL85A705UC 24 in. Built-in...
Dishwasher siemens is not draining water.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Siemens WFXD8400UC Front Load Washer
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Sep 19, 2009 | Siemens 24 in. SE53200 Built-In Dishwasher
Dibris on glasses afterwash. Dishes not coming clean
First check salt level is ok, the next thing may be it's having problems pumping out after the primary wash.
Try running a hot cycle with a dishwasher cleaner or 2 cups of washing soda, then pull out outlet hose and check it's clear.
Check all filters are clear and in good condition with no cracks.
Aug 05, 2009 | Thermador DW44Z Built-in Dishwasher
Siemens Model SL84-A - Water will not pump into dishwasher
heres a screen on the inlet to the water solinoid that plugs up with calcium alot of the time. shut off the water and take the bottom panel off the unit and you will see where the solinoid is. take off the water and then take the solinoid out and apart to clean. reassemble and you will be good to go.
Jan 11, 2009 | Siemens 24 in. SL84A305UC Built-in...
SIEMENS SE64630GB NOT TAKING IN WATER
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Aug 14, 2008 | Siemens 24 in. SE64A630GB Built-In...
Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Jun 17, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Open Questions:
Dishwashers Logo
461 people viewed this question
Top Dishwashers Experts
