Question about Sansui Audio Players & Recorders
Turning off alarm function on Sansui Box Radio with AUX inpute
Hello
The product code is SAN0100 and the barcode reads 9329474018757. I'm not sure how to turn off the alarm function once it has been set. I can stop the alarm when it goes off, but not permanently. I thought turning the volume to 'off' would have been the obvious solution but the sound from the alarm is not affected. The instructions do not provide any insight. Any suggestions would be greatly appreciated.
Thankyou
gadget
  • 14 Answers
SOURCE: playing itunes through receiver
On the back of your tower you should have auxillary outputs that will go into your receiver. Get a connection going between the two ports and you should have perfect sound. The sound that comes out of your headphone output will not really have the amount of power that your receiver needs. Hope this helps.
Posted on Sep 15, 2006
SOURCE: turning off alarm
step through the data/time by tapping the MENU button. you should see date->alarm->alarm1->alarm2
when you get to the alarm displays, use the arrow keys to select -:-- . Hope this helps.
--dio
Posted on Jan 11, 2008
SOURCE: Wharfedale Micro cd/clock radio alarm volume!!!
Same problem with same device.
Posted on Apr 01, 2008
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
SOURCE: operating instructions for timex t311t radio/alarm clock
Regarding how to set the time on a T311T Clock:
1. Push down the Time button and hold until number start flashing.
Push the right arrow until the time advances to the time desired.
2 To set the date, push the date button and hold until date starts flashing. Push the right arrow until the date advances to desired date
Posted on Jul 19, 2008
No aux audio ford edge
The ford radio has two Aux out puts. one of them being a usb jack. if that is the input you are trying to use plug the device in and use the voice command and ask it to select usb.
Apr 06, 2013 | 2010 Ford Edge
Aux input not working
I have the exact same problem. Did you ever get this fixed? If so, how?
May 16, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
My battery went dead and I exchanged it with a new one, but after installing the new one the radio and drivers side window stopped working, I took the drivers door panel off and found a front door module...
The radio may very well have an alarm on it. If it does, then disconnecting the battery to put in a new one can set off this feature, and make the radio unuseable until a code is entered. Does the radio ask for a code?
A memory saver (aux voltage input device) can be used to keep enough power in the system so it will not trigger a radio alarm.
If you don't have a radio alarm, then check the fuse for the radio, as it may have blown when reconnected.
Not sure about the window.
Jan 15, 2010 | 2000 Jaguar XJ
Find radio code (renault clio) model no: 22DC259/62F SERIAL NO: RN259FY0232262
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here  for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
A Renault normally has a 14 character Serial Number beginning with
RN++++++++++++  plus a Security Code in the format TOX123 or TX123 or just X123 at the end of a barcode ...so please quote EVERYTHING you can find.
Otherwise try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Oct 29, 2009 | Philips Car Audio & Video
How to hook up a sansui classique 350 reciever to a tv
Are you wanting to play he audio from your tv through you Sansui Stereo. If you have audio outs on you tv then connect them to the aux input of the receiver. If you ae using a cable box r sat reciever you can connect the audio out from these devices to the aux or any input other than phono input of your Sansui receiver.
May 01, 2009 | Televison & Video
Stereo in my Fiat punto 2007 model has an AUX function. Can i connect cable to AUX Input to run MP3 player via ear peice output?
Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
Jun 17, 2008 | Blaupunkt Car Audio & Video
Playing my ipod on AUX mode????!?!?!?!?!!!!??
HELLO, ON THE IPOD BOX ARE SEVERAL NUMBER CODES. THEY HAVE TO BE SET TO THE RIGHT NUMBERS ON OR OFF BEFORE THE FACTORY RADIO WILL READ THE BOX. ONCE THE CORRECT NUMBERS ARE SET FOR YOUR VEHICLE THE AUX BUTTON WILL WORK JUST FINE. IF YOU DON'T HAVE THE BOOK WITH THE CODES IN IT. JUST COUNT THE WIRES ON THE ADAPTOR AND THE LOCATION OF THE PINS THEY CONNECT TO. THEN PUSH ONLY THOSE PINS UP IN THE ON POSTION. GOOD LUCK!
Jun 07, 2008 | 2003 Chevrolet Avalanche
How do I turn on the "external aux" for my pioneer DEH-p7000r
You'll need an adapter cable such as this one:
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=ip+bus&i=469PIOPRCA
The adapter cable will convert the changer port on your head unit into an AUX input with dual RCA jacks. Once connected, the head unit will detect the cable and allow it to be another source (i.e. radio, cd, aux).
To connect your iPod to the adapter cable, use any iPod cable or dock that outputs to male RCA plugs.
Apr 01, 2008 | Pioneer DEH-P7000r
I have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Aug 30, 2007 | Pioneer DEH-P3000 CD Player
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
90 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
