Question about Stihl GUIDE BAR 16 in STHIL CHAINS
Want keep running after several times of starting it
I choke like all ways start cutting it shut off. I repeat the same step several times shut off. clean carb. took screen out of exhaust ck. when it is hot for spark it has a spark. thanks
    Sergeant:
  • 322 Answers
Will it continue to run on choke? if it does you have an air leak, if not then you may have a faulty carburetor that isn't stopping the flow of fuel and it is flooding itself out
Posted on Jan 17, 2013
4 Suggested Answers
  • 4088 Answers
SOURCE: starts fine runs good for 1-2 minutes then dies.
Check the fuel filter and muffler for plugging. Check the fuel tank vent for plugging. Check the fuel lines for damage or decay. Check all of the carburetor fasteners for tightness including the mounting hardware for the carburetor to the cylinder. The carburetor does not appear to be pulling new fuel into itself after running on the initial prime. If the above hints don't help, you may have to service the carburetor. Check the gaskets and heat insulator block behind the carburetor for any obstruction/damage of the impulse passage which allows the carburetor to pump fuel. Hope this helps!
Posted on Jun 17, 2010
SOURCE: have stihl O25 chainsaw, starts, runs about 5
hey have the same o25 stihl,great saw when their working right.have had to replace fuel line to carb 5x over 7yrs.hairline crrack and it will **** air and conk out in 2-5 seconds.also there is a pulse line to carb which can also crack.if you have good spark at plug its likely a fuel delivery problem. collin
Posted on Jan 15, 2011
  • 3 Answers
SOURCE: stihl 025 starts but cuts out have replaced spark
check the spark arrester screen in the muffler. if they stop up it will run like it has
no power and will stall
Posted on Dec 05, 2011
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
you have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
Nov 19, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
3cyl 993cc daihatsu engine starts and runs then shuts down could this have something to do with the fuel cut solonoid
If you can keep it running with the choke set, your engine is starving for fuel, your fuel filter, or carb is clogged. disconnect the fuel line to the carb and check for flow. Fuel cut would do just that, cut ALL fuel so choking would not matter.
Mar 30, 2014 | Vehicle Parts & Accessories
Start up after sitting long time
After sitting a long time
1. drain all gas as alchol in gas absorbs water BAD!!!
2 mix new gas + oil correctly and fill tank
3 spray starting fluid in carb.
4 put full choke
5 set throttle
6 pull till engine pops
7 place choke to half choke and pull a few times to start
8 repeat steps 3 to 8 until running
Other problems are bad gas lines
problem with spark
Bottom line the engine should at least burn off the starting fluid
if it continues to stop the carb is going to be cleaned
Nov 21, 2013 | Garden
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Jan 04, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to adjust the air/mixture screw on a 25-4cc RYOBI blower vacuum
I start with the screw about 1 1/2 turns out from fully seated (turned all the way in) but be careful when turning it all the way in not to turn it too hard as you can damage the end of the mixture screw. This should get you close enough to fine tune it.
Aug 18, 2012 | Echo Garden
Bought a Poulan Wild Thing 18" gas chainsaw (P4018WT) secondhand from someone who only bought it to cut down 3 trees. It will not start. I know that it works, as the guy started it up and showed me how...
Don't prime it 6 times.
Prime it once and try starting. Keep trying with one prime.
If that doesn't work, let it sit for a bit. And then prime it two times and try starting again.
If that doesn't work, try priming 3 times.
Then try half-choke with one pull only, and then move choke to run for the second pull.
The saw might have an on-off button
Oct 15, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Weedeater is usable and ready, don't know how to start it
I hope you have fresh gas and 2-cycle oil mixed up! They always seem to start strong and explosively cut on good, fresh fuel. :D
1:Choke on.
2:Push the primer bulb (rubber ball by the side of the air filter) 3 times.
3:Place trimmer on ground. Grasp the handle, squeezing the throttle fully in left hand. Kneel and give that starter a crisp, sharp tug with your right hand. If the engine "hits", then push in the choke until off. Goto step 4.
If it does not give a hint of life, repeat the tug on the line 2 more times. If it STILL does not start, check for a distinct odor of gasoline. Likely, at this point, it is flooded, proceed to step 5.
4: With choke now off, continue to depress the throttle fully and give it another sharp pull on the starter. If it starts and revs? Let it idle for a minute to warm up, then go to work!
5:With choke OFF, press and hold throttle at full. It may take several pulls on the starter rope to see any life. If after 10 pulls and there is still no life, and still smells of gasoline - time to see the Ex about getting the trimmer looked after for some TLC. :D
May 08, 2010 | Craftsman 25cc Gas Line Trimmer
Generac 6500 1988 in R.V.Southwind Two things, both only occur in the morning or when cold (I am in So Cal so not that cold). First, when starting the generator from the dash board starter button the light...
See if there is an oil pressure guage on the dash. When you start the machine it probably has a low oil pressure shutdown which shuts the engine off when you release the start button. This is an interlock. Watch the oil guage and keep the start button engaged until you see oil pressure, release the button and it will continue to run at that point. Your second issue may be a function of the choke. If you are having to choke the engine to start, you may have to play with the choke position to keep from overfueling the unit which may cause it to stall and possibly backfire as it has to much fuel to be burned on the compression stroke, and is igniting occasionally on the intake stroke. Hope this helps. Marvin
Jan 20, 2010 | Generac 5622 GP Series GP5000 6,250 Watt...
Craftsman Lawnmower model #917.377292 won't stay running
pull the carb. and clean it and put a kit in it. This should give you a good start. Do a preventive maintenence of the rest of the engine also.Good luck.
Mar 25, 2009 | Garden
Stihl GUIDE BAR 16 in STHIL CHAINS Logo
62 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
