Question about Sharp 20F640 20" TV
I am attempting to add blu ray player and have hdmi cable with analog connections but am unable to get it installed.
  • 691 Answers
You need to use red blue and green component cable to connect this to a hi definition player. hdmi to analogue is not possible without expensive circuitry as well i know you can buy hdmi to phono leads but they will not work for this kind of application. what outputs does the blue ray player have?
Posted on Jan 11, 2013
How do I hook up my HDMI Blu ray player to my theater system that doesnt have HDMI
You have a few options depending on the entire system.
Do you have the TV audio output connected to the home theater system? In that case, connect the Blu-ray player to an HDMI input on the TV. Then leave the home theater system set to the TV input, while the TV is set to the HDMI input for the Blu-ray player. This is the simplest method.
You could use an audio extractor/converter. Here's an example: https://www.amazon.com/J-Tech-Digital-Premium-Extractor-Converter/dp/B00BIQER0E . This will let you send the video signal to the TV (with a second HDMI cable) and have digital or analog audio sent to the home theater system.
If the TV doesn't have an available HDMI port and the home theater system only has analog audio inputs, you could use an HDMI to component video converter. You'd use something like this: https://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html . (Do not use an HDMI to component cable. Those only work with some projectors.)
I hope this helps. Please add a comment with more details about your TV and audio system for more specific information.
Feb 14, 2017 | Samsung Audio Players & Recorders
Philips quadrasurf TV
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
Sep 08, 2014 | Philips 40MF430B/F7 model Magnavox LCD TV,...
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
How to connect old analog tv to blu ray dvd player
You will need to connect to the component inputs on the TV, red, white and yellow sockets. If the DVD does not have these outputs you can get a converter cable such as this
http://www.ebay.com/itm/HDMI-To-3-RCA-Cable-High-Quality-Male-Adapter-Converter-Cable-For-HDTV-1-5m-/190856204300?pt=US_Video_Cables_Adapters&hash=item2c6fea900c
Dec 27, 2013 | Toshiba MV13L2 13 in. TV/VCR Combo
Can i connect dmp-bd871 to a home theater system
It will depend on your home theater system and TV. If your system accepts HDMI in from other devices and HDMI out to the TV, connect an HDMI cable from the blue-ray player to an HDMI input on home theater system. Then connect another HDMI cable between the home theater system and the TV. This will provide the best video and audio experience.
Another option is connect the HDMI cable from the Blue-ray player to the TV. Connect the audio output of the TV to the home theater system. (This will depend on the TV as well as the home theater system. Some TVs have digital audio outputs; others have analog outputs. If your home theater system doesn't have the same input as the TV's output, you would need a converter as well as the digital and analog audio cables. This is an example of one for digital to analog: http://www.gefen.com/kvm/dproduct.jsp?prod_id=4907 .)
If you do not want to get the best picture from the Blue-ray player and your home theater system has analog audio inputs, you can connect the composite video out to the TV. Then connect the audio outputs from the player to your home theater system. (This means only an SD picture will be provided to your TV.)
Panasonic has the manual for the DMP-BD871 here: service.us.panasonic.com/OPERMANPDF/DMPBD871-MUL.PDF .
I hope this helps. Please add a comment with the other devices in your entertainment system or their inputs/outputs. Then I can add specific information for your system and any tips for setting up the system.
Nov 26, 2012 | Panasonic DMP-BD871 Blu-ray Player with...
I have purchased the blu ray dvd player do i need to by a coaxial jack as well as the hdmi jack
No,a HDMI cable alone will do the job.Just plug the HDMI cable one side connected to the HDMI port hub belong to the tv HDMI hub,the other side of the HDMI cable connected to the HDMI port hub belong to the Blu ray dvd player HDMI port hub.That should play ur Blu ray dvd player.U still have questions,read ur owner manual.
Jun 24, 2010 | Televison & Video
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sharp 20F640 20" TV Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
