Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Gaggia syncrony logic not grinding beans
My gaggia machine is struggling to grind beans, it has been cleaned thoroughly, it is spinning very slowly without beans in, as soon as you add beans it stops, as if there is no power in the motor, any suggestions welocme, thanks
  • Gaggia Expert
  • 109 Answers
The unit requires a new grinder assembly
Posted on Jan 26, 2013
SOURCE: Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Posted on Jul 17, 2007
Buffalo12980
  • 625 Answers
SOURCE: Gaggia Titaminu
check to make sure the blades are secured to the motor shaft. some have a set screw, some are positioned over a pin in the motor shaft.
Posted on Sep 11, 2007
  • 3 Answers
SOURCE: Gaggia Syncrony does not get past the grind cycle
You hit it on the money, Jose... the grinding burrs, called the conical burr set in the manual, needs replacing. You can find it at partsguru for around $42, and armed with a standard phillips head, a larger precision phillips head, and a #10 Torx head set of screwdrivers, you can replace them yourself, saving over $300 in repair bills.
Email me for the step-by-step if you want to give it a shot.
Posted on Nov 02, 2008
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
SOURCE: No power to Gaggia Syncrony Logic
Re the Gaggia no power problem, the machine does have a re set button, 2 in fact the boiler unit must be removed and the two reset switches are between the sender units (brown in colour).
After disconecting the power source open the machine (top off)The three alan head screws that retain the boiler (front of the machine) unit must be removed it can be lifted clear to gain access to the bottom of the unit where the reset buttons are.
This will save hundreds of dollars in shipping and service fees.
DIY takes about 10-20 min well worth it.
Take care when doing this opperation 240 volts can kill.
Posted on Feb 12, 2010
I have a gaggia syncrony logic that has just come back from the repairers.! The coffee dregs are almost liquid whereas before they were solid patties & liquid is found in the drip tray after every...
The coffee grind could be too fine and or not enough coffee is being added to the brew chamber after the machine grinds it. You can try to adjust the amount of coffee being used for an espresso and or adjust the grind.
May 20, 2011 | Gaggia Syncrony Logic 74884 Espresso...
My machine is having a problem grinding the coffee it is gringing it but very slowly
HI
Its probably set to fine in the bean hopper. The big knob in the bean hopper should be set around 8. If its lower than that you need to turn it up. If you have 2 knobs in the bean hopper you can turn the small knob towards the + side, but not all the way for stronger coffee.
Jan 15, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Its telling me that coffee beans are empty...but they are not..it makes grinding noise but the message keeps popping up beans are empty
You have one of 2 problems either the grinds chute to the brew unit is blocked, or the grind is too fine.
Sep 18, 2010 | Gaggia Syncrony Compact Coffee...
I have a gaggia syncrony logic.The coffee beans are not going to the grinder so the grinder is just spinning,we have cleaned the machine and cant tell if something is stuck in it or what. cand you help?
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 27, 2009 | Coffee Makers & Espresso Machines
Beans grind, then the machine sounds like it's 'struggling' mechanically, then it just gives up and clears the ground beans out before pumpng any water. I think the problem is mechanical, but am not...
really hard to repair these yourself. User access limited. Brew unit may have spent coffee stuck in it or it may be blocked. Best return to service centre
Sep 19, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia machine sounds as if it keeps grinding but no beans are getting through the grinder. I have cleaned machine completely, emptied the beans, opened the grinder to the biggest setting and still no...
The grounds chamber/gate might be blocked you will have to clear it out. Remove brew unit and find discharge for grinder, then push gate back and clean.
Aug 25, 2009 | Gaggia Syncrony Espresso Machine
No beans
I think it´s the micro switch in the machine that is the problem.
Jul 01, 2008 | Gaggia Syncrony Espresso Machine
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
Feb 24, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
325 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
