Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba laptop tripped for heat
After 1 hour running of laptop base high heat found and then tripped, when again battery disconnected and again connect then again it start.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Get some canned air like Skilcraft Power Duster and blow out the fan area, clear it from all dust - you need to remove the case and blow it out or be lazy and just blow it out w/o taking it apart, but I suggest you remove the case to give the dust somewhere else to settle besides back inside of your laptop. The other thing to look into is where were you using the laptop - a peer of mine kept having a similar issue until I went over to his desk and moved the space heater from directly under his work area. Also go have the battery tested. A bad battery could be causing the issue as well. Once you've done all that if the problem happens again go get a cooling pad they run about $25 but will save your investment and time, but the other things should remedy the problem.
Posted on Jan 11, 2013
Check to see if fan area has does in it. You can either take apart and blow dust out or try blowing without taking apart. I would take it apart. Also, check for firmware update which may address overheating problems.
4 Suggested Answers
  • 81 Answers
SOURCE: Toshiba Satellite 2410-PS241L laptop does not start.
Plug it into the electrical outlet and then turn on your laptop. if it comes on and works fine, then your battery is just simply dead, and if it will charge, just needs to charge. If not, then you are going to have to replace your battery. But assuming all of this is true, and your laptop will power on when using your electrical outlet, then yes, feel free to use it whenver you like when plugged in.
Posted on Sep 05, 2008
SOURCE: Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Posted on Oct 04, 2008
  • 1768 Answers
SOURCE: Toshiba Satellite P30 (new) Battery (and old) not charging
1. You will need to check the power adapter it may have lost it's ability to send a charge to the board.
2. Also the connector to the PC may be damaged and the solder joint at the mother board may have cracked or damaged.
3. Check also that you have the battery completely snapped in place.
4. check the contacts on the battery itself.
5. You PC may need service.
Posted on Mar 27, 2010
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
I need help with one thing, and I also have a sepa...
You should buy the replace battery for your laptop.
Discover is great: Replacement laptop battery
May 19, 2010 | Toshiba Satellite L305D-S5881 Notebook
High limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Apr 22, 2010 | Dacor ECS130 Epicure Electric Single Oven
Needs to be pluged in to boot, but will run 1 hour plus on battery after boot. Lights come on, fan blows the it sits, no acivity. From that state plug in power, video and hard drive start to normal...
sounds like a bad battery, it takes more power to start then run, and once running windows will adjust power usage based on availability. If the amperage of the battery is insufficient the laptop will turn on but won't boot
Mar 28, 2010 | Toshiba Satellite M35X-S111 Notebook
No heat inGLEQ2152ESO what's the solution?
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
4. Check the operational value of the high limit thermostat as well. replace if found to be faulty.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Toshiba satellite pro 4200 wont start,just 1 flashing amber light
I had a similar problem on SatPro6100. Mine was LSSSLSSL (10010001).
Thinking that the laptop was buggered I decided I would take it apart and have a look at the insides.
Whilst it was apart I also disconnected the BIOS battery.
Couldn't find anything that looked like it had burnt out so put it all back together again.
When I turned it on again the darn thing was working fine!!!
Go figure!!
The whole thing was apart for about 2 hours or so.
I don't know if it was removing the main battery and leaving it out for that time or whether it was resetting the BIOS (by disconnecting its battery) that fixed the problem.
Anyway, I have managed to get all my data off the laptop so not too worried if it screws up again.
I do however always disconnect the power source BEFORE shutting down the laptop and only reconnect it after I have pressed the on button. Seems to be working fine (for now!)
Hope that helps someone out there!
Mar 11, 2009 | Toshiba 20GB 5400 RPM NOTEBOOK HARD DRIVE...
Irregular power supply to toshiba satellite M100 laptop
hi there,
i would like to know how old is your laptop.?
new laptop less than a year can operate on 1- 3 hours.
older laptop 2yrs above can only operate at 1 - 1 1/2 hours.
first for an initial help try removing the battery pack and put it back in properly,
let me know again here.
thanks
Dec 06, 2008 | Toshiba Satellite M100 Notebook
My laptop has been on ''preparing to hibernate'' for hours. frozen
Simply, disconnect the power cord, remove the battery, then hook it back up again. I wouldn't do this though if you unsaved stuff running though.
Nov 13, 2008 | Toshiba Satellite A205-S4617 Notebook
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
