Question about Exercise & Fitness
Proform Perspective 1.0 LX panel keeps resetting, displays 8's
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: No buttons on my proform 585 perspective treadmill
adjust the REED swtich, test for open or faulty, tight the plug very well
see the diagram attached.
2) Tight the Ribbon cable from keypads and clean it.
3) Tight the connectors for upper board vs lower board
4) replace the batteries with FULL charges, with the same polarity, with the same mark. clean the contacts batteries very welll, and try again.
see the block diagram attached.
God bless you
Posted on Dec 18, 2012
ercupa190
  • 12223 Answers
SOURCE: Belt is sliding to right and is loose how do I tighten it? Proform Perspective ES
see the diagram attached and use the common sense:
God bless you
8_30_2012_4_32_35_pm.gifthe first if for to tight8_30_2012_4_33_22_pm.gifthe down is for loose.
Posted on Aug 30, 2012
Proform perspective 1.0 lx console cycling off and on
There may be a problem with the wire lume that connects the LCB to the console.
Nov 10, 2013 | Proform Exercise & Fitness
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Oct 13, 2012 | ProForm 70 Perspective Treadmill
God bless you
Aug 30, 2012 | Proform Perspective Es Treadmill PFTL99806
Proform 831 threadmill
Dear Sir:
You have a serious problem:
Do the following step:
1) Test the power from outlet wall.
2) Test it for ground in the outlet wall.
3)power cord test for loose cable.
4) Reset c.breaker from the treadmill
5)test the transformer for voltage input and output(primary and secondary ).
6)Power supply see if there are some component burn or loose wire or melt.
7)See if there are +5 Vdc for digital circuit(main motor board.(
8) Run the calibration software under the Hood motor is the instruction. for diagnose.
attached the block diagram.
sincerely.
ernesto cuadra
managua, nicaragua c.a.
Feb 13, 2012 | Proform Exercise & Fitness
I have a proform xp 620 treadmill and the control panel keeps shutting off and on. i can start walking then it shuts off and then seconds later it comes back on
adjust the sensor switch first.2) change the batteries if have it.3)tight the flexible cable vs display board.4) tight the connector from display board vs lower board.
If the problem persist.you must test the following:1) Test the main motor.2) See if the drive belt is broken, loose, or slip3)finally the main motor board possible is faulty
see block diagram12_1_2011_11_16_04_pm.gif12_1_2011_11_16_27_pm.gifgood luck.
sincerely.
e.cuadramanagua,nicaragua
Dec 01, 2011 | Proform XP Weight Loss 620 Treadmill
My proform xp 620 treadmill starts up fine and I can walk on it up to 4 mph. However, when I try to go up to 5 mph, the belt stops moving and the display screen goes blank.
1) adjust sensor reed switch or optical disk by 1/8" aprox and replace if neccesary after if the problem persist.
Chech the plug connector console panel vs. and controller board. If everything is wrong the console panel is bad.
Aug 22, 2011 | Proform XP Weight Loss 620 Treadmill
Proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
May 26, 2010 | Proform Perspective Es Treadmill PFTL99806
Exercise & Fitness Logo
127 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
