Question about HP DesignJet T520 ePrinter
HP Design Jet T520 Paper Size error message
Paper size error message
  • 4 Answers
SOURCE: HP 1280 Error message
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
SOURCE: hp 7760 won't print comes up with error
http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=946530
The solution is here, in step 8:
"NOTE: If none of the options resembles the paper being used, select Plain paper. Do not leave the type is box set as automatic."
Who'd have guessed?
Posted on Jan 27, 2009
  • 154 Answers
SOURCE: Hp Photosmart C5280 error message "wrong paper size or type"
set it on control panel of printer
Posted on Apr 24, 2009
  • 53 Answers
SOURCE: It doesn't print It says size paper error
-Check to see if the printer diver is fully installed or installed correctlly
-Check paper and size setup to see if the size of the paper that you choose is suppoted o not.
-check your print setup
Posted on Oct 06, 2009
SOURCE: Paper Size Error: The specified custom paper size is not supporte
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Posted on Oct 20, 2009
Manual laser jet 4
The paper size selection knob or MP paper size does not
match the installed paper or more than one sheet of paper
was picked up.
Oct 23, 2011 | HP Hewlett Packard LaserJet P3005n Printer
Error message 41.3 paper error How do I fix?
Error 41.1 41.2 41.3
  • Defective connections. Reseat J205,206,207 and laser scanner connectors.
  • Paper multifeed or wrong size paper being used.
  • Paper size selection doesn't match the paper being used.
  • Cassette is overfull or improperly adjusted
Dec 16, 2010 | HP LaserJet 4 plus Printer
I REPLACED MY INK CARTRIDGES. I WAS PROMPTED TO
Ignore the error and continue printing. The print job might still be acceptable even if the paper size and paper type settings are not an exact match.
  1. Press Enter on the control panel to clear the error message.
  2. Try the print job again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
    Use the HP product software, also known as the printer driver, to change the print settings for your paper size and type depending on your version of Microsoft Word.
    1. In Microsoft Word, click File , and then click Print .
    2. Make sure that your HP product is in the Name drop-down list box, and then clickProperties .
    3. Click the Features tab, or the Paper/Quality tab.
    4. Select a paper size from the Size drop-down list.If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
      1. Select Custom from the drop-down list.
      2. In the Custom Paper Size dialog box, type a name for the new custom size.
      3. In the Width and Height boxes, type the dimensions.
      4. Select the unit of measurement, and then click Save .
      5. Click OK to close the Custom Paper Size dialog box, and then click OKagain to close the Properties dialog box. NOTE: You must exit the Properties dialog box to apply your changes.
      6. Open the Properties dialog box again, and then select the new custom size from the Size drop-down list.
    5. Select the paper type.
      1. In the Paper Type or Type is drop-down list, click More .
      2. Click the desired paper type, and then click OK .
    6. Select the paper source from the Paper Source drop-down list.
    7. Change any other settings, and then click OK to close the Properties dialog box.
    8. Try the print job again.
      Paper mismatch errors occur because the printer scans the width of the paper before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper Mismatch' or 'Paper too Narrow ' error.The error message might also display when you load the correct paper, just reinstall the printer driver if above procedure does not helps. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP 7410 Paper Feeds in Crooked
The paper size in the feeder and the paper size in your printing properties have to match.
I.e. if your printing format says "letter size" and in your feeder is legal or A4 paper you will get this error.
Please reply if this does not help.
Dec 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Paper size error when copying - Office jet 7210
I got the same error, and had it for months. open the ink door where it says office jet pro, it folds towards you, wait for the ink cartage to position to the left, then look inside and far to the right, and see if there is a wadded up peace of paper inside. Reach in and pull it out, it fixes the problem
Dec 06, 2008 | HP Officejet 7210 All-In-One InkJet...
Wrong paper size message
Choose the correct paper size from the setup and change the paper type to 'plain paper'.
Hope this help.
Apr 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP DesignJet T520 ePrinter Logo
124 people viewed this question
Seeker5211
Seeker5211
