Question about Microsoft Excel for PC
Formula help cell b1, 328.06. cell c2 46 (%). cell d2 answer 177.15. so i want to take 46% away from 328.06
  • 1 more comment
  • Anonymous Jan 24, 2009
    erwr
  • Anonymous Jan 30, 2009
    NBV GGKK HGGGFFFF
  • Anonymous Feb 04, 2009
    how i creat vlookup formula
Deffence two excel pages
Posted on Jan 29, 2009
    Problem Solver:
  • 6 Answers
You should either use this formula to remove 46% from 328.06. The first option is =B1-(B1*C2) wherein you should deduct 46% from B1 or just compute for the 54% of B1 which is =B1*56%.
Posted on Jan 22, 2009
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
Need to take create a formula that takes a cell
Hi sug04
These are couple of solutions
First. Solution
  • Take away 20% means the answer is 80%
  • 20% means 0.2 of a number, 80% means 0.8 of a number
  • So If you have 200 in Cell B1
  • And you want 20% less in B2
  • Goto B1 type 200
  • Goto B2 type like this =B1*.8 and press ENTER
  • Now Cell B2 displays 160 which is the correct answer
Second Solution
  • Goto B1 type 200
  • Goto B2 type like this =B1-(B1*.2) and press ENTER
Good luck, have a nice day
Please give a Rating to this solution
luciana44
Sep 17, 2009 | Microsoft Excel for PC
Finding the correct row num
You would have to combine the use of 2 functions. The Address and Match funbctions.
Lets say the number you want the address of is located in cell F1 and you have 2 columns of numbers. One colum in Column A and the other in column B. I will give you 2 formulas. The 1st one will return just the row number. The 2nd one will return the cell address.
Option 1: Lets say you just want to know the row reference of the number in cell F1. Place this formula in cell D1. =MATCH(F1,A1:A20)
If you have another column ytou want the row number of, place the formula in lets say cell D2 and change the column references from 'A' to 'B'.
Option 2: If you want the cell reference, place this formula in cell D1 and D2 instead of the firt formula.
=ADDRESS(MATCH(F1,A1:A20,0),1,1,TRUE)
And just like the first option, for the 2nd column, put the formula in D2 and change the column reference 'A' to 'B'.
Feb 17, 2009 | Microsoft Excel for PC
Excel farmulas
Add another colum, say D with result of B*C
Do a list of the different cat, and use sumif
For cat 0101 (in cell F1)
formula to put in G1
=sumif($A$1:$A$7000;F1;$D$1:$D$7000) where F1 contain 0101
expand the formula for other cat. (G2, G3, etc)
You can use a assistant to extract the distinct cat from A1:A7000, sorting them and copy the result in F (Menu Data-> Filter -> elaborate filter)
Feb 16, 2009 | Microsoft Excel for PC
Excel formula,
the basic idea of an if statement is just that if this then that. Thus a formula could look as simple as =IF(A2=1,25,IF(A2=2,10))
Jan 10, 2009 | Computers & Internet
Microsoft excel
this is done through formulas. You write them in relationship to one another. Say you put a value into B1 then you write a formula for c2 like =SUM(A1/2)which means the sum of A1 divided by 2. or you can say make a formula that is like this =SUM(A1/C1) which means the value of A1 divided by the value of C1.
Percentages in Excel
No problem, Melinda, I am here to help!
If I understood correctly, your spreadsheet looks something like this:
A B C D
1 Question Yes No Total
2 Is sky blue? 20 2 22
3 Is world round? etc.
In this case, the formula for % of Yes would be: =B2/D2. This would give you a decimal point result such as 0.909091. Now if you want to make this look like a percentage in your spreadsheet, just do the following:
1) click on the cell where you have the division formula
2) clck on Format in the top menu bar
3) click on Cells
4) click on the Number tab (if you're not already there)
5) click on Percentage in the list of categories
6) click OK
To boil it all down to a simple principle, percentages are created in Excel by dividing the two numbers using a formula with "/" in it, and then formatting the result to look like a percentage instead of a decimal.
I might have misunderstood your question, and I have an idea of what else you might have been asking (and another slightly more complicated solution for it!), so please let me know if my first answer didn't hit the mark!
Good Luck!
Regards,
RichMTech
Aug 08, 2008 | Microsoft Excel for PC
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Help with simple excel calculations
Hello.
For cell B1 you can use this (without the quotes) "=A1"
Then for cell A2 and down you don't need a formula, but for B2 you can use this formula. "=(B1+A2)" Then click on that cell and drag the mouse down for as many cells as you want this formula to include and press Control and F keys to fill the formula down the column.
For your second formula, you would type 100 into D1 and in D2 you would use the formula "=D1-E1" (again, no quotes).
Feel free to let me know if you need any more clarification or if I missed something!
Jun 10, 2008 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
