Question about Lorell 60986 Radio Control Wall Clock
Lorell radio controlled clock - Lorell 60986 Radio Control Wall Clock
Cannot set time
WWVB Radio Controlled Clocks
www.nist.gov/.../radioclo...
National Institute of Standards and TechnologyFeb 11, 2010 - To find out more about WWVB radio controlled clocks, please ... Before it does so, it applies a time zone correction, based on the time zone setting that you ...your radio controlled clock, but we cannot provide technical support ...
[PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ..... The alarm time setting cannot be changed if ALARM.
[PDF]Atomic Analog Wall Clock - La Crosse Technology
https://www.lacrossetechnology.com/.../Generic_Headway_Manual_050...
clock is synchronizing to the WWVB signal and once the radio signal is decoded, the hands will ... trouble free. If the clock receives a clear time signal, it will set itself perfectly. ... A: No, the clock cannot work with a booster antenna. Opening the ...
ICF-218 Sony Alarm Clock - YouTube
? 1:50
https://www.youtube.com/watch?v=XTQ8zEMMNq8
Aug 4, 2012 - Uploaded by sohvintage
Jan 10, 2016 | Audio Players & Recorders
How I set the time on the radio?
Depends on the radio.
General idea is this:
turn radio power off on face of radio. Clock should show.
push button such as SET / CLOCK / TIME
push other button HOUR MIN up down seek scan ff rew (one button will control hour other button will control minute)
turn radio power back on. clock should remain set.
Dec 06, 2014 | 1993 Buick LeSabre
Replaced battery time will not set
place it closer to the window until it sets
Nov 27, 2013 | Lorell 60993 Radio Controlled Wall Clock
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
Does it come with a remote control device?
Hey there! Not all of the clock radios come with a Remote control. However maybe they have available Universal Remotes that might work for them. But I've haven't seen any clock radios with a remote device.
Thank you for using FixYa.
I hope that I helped you & that this post helps you at most!
Don't forget to rate! =]
Jan 15, 2011 | Naxa Electronics NX157 Clock Radio
Global atomic radio controlled clock
It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
Mar 16, 2010 | Audio Players & Recorders
Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
Lorell 60986 Radio Control Wall Clock Logo
35 people viewed this question
Top Lorell Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lorell Audio Player and Recorder Expert? Answer questions, earn points and help others
