Question about SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader
8 gb card unlock on canon elph screen
I put brand new SDHC card in digital elph to save more pix and the screen reads MEMORY CARD ERROR: CARD LOCKED .How the F%$# DO i UNLOCK THIS JISMO?
  • 1 more comment
  • Anonymous Apr 11, 2009
    I am having the same problem, and it has nothing to do with the little tab that you can slide to lock/unlock the card.
  • Anonymous Apr 14, 2009
    when i try to take a picture it says card protected and when i try to delete them it also says that
    GIVE ME MORE MEMORY 9'9 AND GRAPHIC 9.9 MORE
    Sergeant:
  • 319 Answers
It should have a slide switch on the outer casing of the card... write protection lock.
Posted on Feb 27, 2009
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
Why does display read MEMORY CARD ERROR CARD IS LOCKED!
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Oct 29, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Hi there! I have a Canon PowerShot SD700 is. I have bought a Sandisk 8 GB. My camera cannot read it. It says: Memory Card Error. What can I do about it? Many thanks for your help
The SD700 works with MMC and SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
Apr 23, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
4 gb memory card placed into camera. Camera says card error. Why?
The SD630 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in SD devices.
You need to use SD cards, 2GB and smaller.
Nov 21, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
The canon says "memory card
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 12, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Open Questions:
See all SanDisk 8GB microSDHC Memory Card with MobilMate Questions
SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader Logo
214 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
