Question about Acer X1320WH - DLP projector - 3D - 2700 ANSI lumens - - EY.JDK04.018
Acer projector program fios - Acer X1320WH - DLP projector - 3D - 2700 ANSI lumens - - EY.JDK04.018
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
My acer internet does not recognize the internet provider when using wireless card. I have FIOS and it worked well. FIOS had grid problem and internet was down for few hours. Now, it will not recognize...
i could talk you through it but it will be hard for you the best option is go to start then system tools and system restore then restore to an earlier date a date when it was working ok don't worry you will not lose any files the only thing can happen is if a program was installed after the date you selected you might lose it but you can easily reinstall the program you will definitely not lose anything else i hope this helped please contact me and let me know and if it did not i will talk you through the process otherwise you could download firefox and when installing it will ask if you want to import stuff from your other browser check no then it will work fine firefox is better anywaybut when installing makwe sure and unplug the cable and connect through wireless and it will work fine
Jan 10, 2011 | Acer Aspire One PC Notebook
Remote comtrol
Depends on the make of your TV. Here is a link that shows, step by step, how to program your Fios without a code.
http://www.ehow.com/how_5066834_program-fios-remote-code.html
Sep 29, 2009 | Computers & Internet
Missing program
PC CRT (VGA Port) rely on graphics drivers to see projectors. Windows installs generic drivers that should work. Right click "my computer" click manage, go to devices, uninstall VGA adapter driver, reboot. Let system install windows drivers. There should be a FN+F# sequence to redirect or mirror your display on the projector.
Jul 24, 2009 | Acer Computers & Internet
Fios Remote Code for Yamaha SOund Projector
call the 888-553-1555 that is the fios solutions center
Nov 20, 2008 | Broksonic CCVG297 9 in. TV/DVD Combo
ACER 5720 WIRELESS CONNECTION PROBLEMS
Sounds like a bad router or antenna. Try replacing the antenna or checking the connection of the antenna on the router. Have your ISP replace the router and the problem should go away.
Jul 30, 2008 | Acer Aspire 3050-1733 Notebook
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Fios & Olevia
Olevia 3131, 3226, 3231, 3232, 3233
Dec 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Acer X1320WH - DLP projector - 3D - 2700 ANSI lumens - - EY.JDK04.018 Logo
14 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
