Question about Sony KDL40S5100 40 in. HDTV LCD TV
Cannot update kdl40s5100 firmware
Although I follow all the directions (correct usb device - sony microvault 4G, format FAT32, tried download on both PC and Mac, unplugged all inputs, unplugged TV for 5 mins, put usb in rear service port, plug in, power on, and -- nothing. I feel like I'm missing something simple!
Mike258
  • 1498 Answers
SOURCE: PC input to Sony Bravia - from Sony Vaio Laptop - unsupported sig
Hi Julie,
There are a couple ways to go here. I'll give you the procedures step by step. If you want clarification on anything, just ask. If I make an assumption that is wrong, stop me and let me know. The more you know, the easier this will be for both of us.
First I'd like to double check on MisterSony's diagnosis. Refresh rates that are too high end up as a black screen on many LCD models.
This is my first assumption, the display settings are currently for both monitors. Your original screen is still functioning.
If so,
  • Right click on your desktop
  • Click Properties
  • Click the Settings Tab
  • Click the Advanced button
  • Click the Adapter Tab
  • On the lower part of that tab, there should be Refresh Rate. If it is not at 60 Hz, try to change it to 60 Hz.
  • Click OK
  • Click Apply
  • A pop up may appear asking if you want to keep the changes. Accept the changes.
Get back to me with the results. If it was already set at 60Hz. We go to the next step.
Mike
Posted on Nov 16, 2008
wiqi546
  • 1511 Answers
SOURCE: i have a sony lcd and i want to update it
No, Brother.
Sony LCD will only accept "Sony Micro Vault"
So try using sony Data Treveller.
KIndly Do Rate, If helpful.
Posted on Jul 17, 2009
budmrtn
  • 11361 Answers
SOURCE: tv does not turn on
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 27, 2010
eagle338
  • 4889 Answers
SOURCE: content error loading netflix on
Yes it is most likely to be a firmware bug. Did not understand what you meant by "have sony sending firmware update on usb key" though. Can you please clarify this?
Posted on Nov 24, 2010
welcomejee
  • 10594 Answers
SOURCE: "TV Volume is fixed" shows up on Sony model #
Go to Audio Menu and turn On tv speakers option. "TV Volume is fixed" message will disappear.
Click Sony Support link to download user manual copy of this tv and check page-63 fro more details.
Thanks.
Posted on Dec 29, 2010
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
UPDATE error 8002F147
Try a low format FAT 32 in windows with "HDD Low Format" app. Make sure your downloaded firmware has no CRC errors and put it in the root of your FAT 32 usb stick. Do a System Update from the Safe Mode in your PS3. Following this steps should do just fine. Write back to know how it works.
Aug 06, 2014 | Sony Playstation 3 (PS3) Console
I have a Vizio Model E420VL and it gets into a state which the audio does not work (from HDMI input #1) and remote control processing in the unit also does not work. I had played around with the side...
hi,
It can be difficult to get things right on the first try. With that truism in mind, Vizio Incorporated includes USB ports on their televisions that you can use to load firmware updates onto the television. Vizio has released firmware updates only for certain television models, and the instructions for installing firmware updates vary slightly by model. To upgrade your television's firmware, you need to download and copy firmware drivers to a USB flash drive and then read and follow Vizio's specific installation instructions for your model.
1. Connect the USB flash drive to your computer
2. Click the "Start" button, and click the "My Computer" icon.
3. Right-click the flash drive, and click "Format" in the menu
4. Select "FAT32" in the drop-down menu, and click the "OK" button. Windows will format your USB flash drive with the FAT32 file system.
5. Open your Web browser, and navigate to the Vizio support Web site at www.vizio.com/support.
6. Click the "Select Your Product" drop-down menu, and select your model of Vizio television from the list. A new page will open that displays available downloads for your television
7. Click the "Firmware Update" link, and save the firmware update file to your computer.
8. Click the "Firmware Instructions" link, and read the instructions specific to your Vizio television model.
9. Right-click the file that you downloaded, click "Rename," and then rename the file to the exact name that is specified in the firmware instructions 10. Right-click the file, and click "Send to" > "E: USB Drive" or whichever drive letter corresponds to your flash drive. The firmware update file is copied to your USB drive 11. Right-click the "Safely Remove Hardware" icon on the right side of the Windows task bar, and eject the device from your computer
12. Disconnect the USB drive, and plug it in to your Vizio TV's USB port.
13. Follow the steps in the firmware instructions to install the firmware update to your television.
Only you can find is the problem with firmware by udating the frimware of your tv. ok
Aug 05, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
I have SONY BRAVIA KLV-32BX300 TV and I had a problem connecting it with my pc, I tried the VGA cable and the pc with another monitor and it worked fine, so I tried doing a firmware upgrade and followed...
This is indicative of a bad flash; I would recommend formatting your USB stick (FAT32), redownload the pkg update (available here: http://esupport.sony.com/LA/perl/swu-download.pl?mdl=KLV32BX300&upd_id=6232&os_id=25 ), and performing a firmware upgrade again.
Taken from: http://esupport.sony.com/LA/perl/swu-download.pl?mdl=KLV32BX300&upd_id=6232&os_id=25
  1. Turn the TV on.
  2. Insert the USB storage device into the USB port on the back of the TV.
    Note: The USB storage device can only be inserted into the USB port slot one way.
  3. Turn your TV off by pressing the power button on the TV
  4. Press the POWER button again. The POWER indicator will be green for 30 seconds, followed by the PIC OFF/TIMER indicator slowly flashing amber, and the STANDBY indicator is red.
  5. After several minutes, the TV will turn off and then turn back on to complete the update.
  6. Remove the USB device from the TV.
Mar 14, 2011 | Televison & Video
BD-HP21 cannot find update on my flash drive. Formatted the flash drive twice (FAT32 & NTFS) extracted the zip file on to the hard drive and copied the update file to the flash drive. Help!
Let's start from the beginning again. Go ahead and reformat your usb device to fat 32 wiping everything. Next go to www.sharp.ca
Click on Service Support on the left and next click on downloads. Select Bluray, next and then your model number, done.
Then save the firmware directly to your usb device.
If the usb device is larger than 4GB it might not work.
If the download still does not work try formatting the usb device again this time to fat and then dowloading again.
You may need to reset the bluray player. Hold down the power button on the front of the unit until it says reset. Then put the usb device into the player before turning it back on. Press setup-->settings--->software update.
May 05, 2010 | Sharp BD-HP21U Blu-Ray Player
Sony walkman b135 say boot error after that power
Dec 26, 2009 | Sony Walkman NWZ-B135 MP3 Player
I have Sony walkman NWZ-B135F MP3,Walkman well. when i power on the player it says boot error and immediate shutdown..........
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
if not , mail me : hamidjoush@yahoo.com
Oct 07, 2009 | Sony NWZ-B103FBLK MP3 Player
Not formatting
I had the same problem with my 1GB SONY MicroVault Clip flash drive. Hardware and the drive shows up on Vista, but it refuses to open or format it.
1) IT MANAGED TO REFORMAT NICELY ON WINDOWS XP!!!! So try this, or
2) When the Micro Vault does not operate well, please download the format software from a "download" button and re-format the Micro Vault. http://www.sony.net/Products/Media/Microvault/products/usm-l/dl.html
hope this helps guys!! :D
Apr 23, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Sony microvault 2 gb pen drive- can not copy file- I/o device err
My 2gb sony microvault is asking me to format. It is teeling me that it is write protected. How do I format it
Apr 16, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
No sign of life - suspect battery problem
Press the Reset button of your player (if it has one).
If this still won't turn on, go to the Sony Support Center to download a firmware software for your player.
But first, you should go to the Device Manager and search for your player's icon. Then click on the icon, click Properties, then click on the Driver tab, and then click on Update Driver. Don't let the wizard to search for the driver on Windows Update, nor let the wizard search for the driver automatically. But choose Don't search. I will choose a driver to install. Then select USB Mass Storage (first uncheck Show compatible hardware, if checked). Click Next, and then the wizards installs the driver.
Now you may open the firmware software application. The wizard installs the firmware on your player. Then click on the device icon on My Computer. If Windows asks you to format it, then click on Yes.
Format it using FAT. If that didn't work with FAT, use FAT32. Then unplug the device (Do not open the browser after you formatted the device using Windows).
Turn it on, and you're done!
Good luck, and Happy Holidays.
Nov 28, 2007 | Sony Walkman Bean NW-E307 MP3 Player
Sony KDL40S5100 40 in. HDTV LCD TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
