Question about Saws
I need a bellows, part #4670-056-70 for craftsman 149.236160 scroll saw
Sears of course no longer sells the part, something even close I may be able to jerry rig.
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
philschneide
  • 448 Answers
SOURCE: need owners manual for Sears/Craftsman radial arm
If you go to http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=113.199250 you will see a "get manual" indication over on the right hand side. Manuals are in PDF files so you will need Adobe reader (free) if you download it.
Hope this helps you.
Posted on Oct 16, 2009
SOURCE: Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Posted on Dec 04, 2009
  • 10 Answers
SOURCE: missing parts for guard assembly craftsman table saw 133.299315
I sell parts on ebay, I have many blade guards. not sure on your model # you sure it isn't 113.xxxxxx????? "Hokienpokie" ebay, or contact me via email " jimatcavanaungh@cs.com" probably be abble to fix you up, Jim
Posted on Feb 12, 2010
I need the yellow key for my sears/craftsman 10 inch saw model no. 113.196221 where can I get a key?
Unfortunately this part is no longer available. However, saying that, the scroll saw might have the same size if you want to try.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113235501/0247/0744440?blt=05
Another solution, is to purchase the complete switch from the scroll saw. Have you tried your locat Sears store in their repair shop. Sometimes things are squirrelled away.
Feb 06, 2011 | Garden
Need electric motor for model #113241680. what is the rpm and horse power.
here is the sears parts for your saw
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113241680/0247/0744600?pathTaken=
looks like they dont sell the motor any more. as long as you have the spec plate on your motor you should be able to match up something from a parts house or anyone that sells electric motors. in my area its Granger
Dec 28, 2010 | Craftsman 10" Table Saw
My 16" craftsman scroll saw has a rubber tube that
The tube can be replaced with the plastic tubing used for aquarium air pumps that you can find in most pet stores. Unfortunately you have to disassemble the scroll saw arm to replace it. Remove the 6 screws at the back of the arm assembly, then the 4 bolts that hold the arm to the base. This will allow you to split the arm and you will find a plastic bellows that the hose connects to.
Nov 13, 2010 | Craftsman 16" Variable Speed Scroll Saw
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 | Sears Saws
Scroll saw Model 572.247200 need manual or at least what saw blade it takes??????
According to the Sears web site, your sroll saw uses the #8030 blades, which have been replaced with #5088029. These are available from any Sears store or online at the following link, see item #31 or 31A, priced at $4.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=+572.247200+&productCategoryId=0744440&brandId=0247&modelName=CRAFTSMAN-15-INCH-MOTORIZED-SCROLL-SAW%2FSANDER&diagramPageId=00001&documentId=00033222&pop=flush
It would appear that the owners manual for your scroll saw has been discontinued and is no longer available (Sears #405015) But the line drawing and parts list may be of some value to you, should you need to do any repairs later on.
I hope you find this Very Helpful and best regards!
Oct 23, 2009 | Saws
Missing parts for guard assembly craftsman table saw 133.299315
You will have to start searching craigslist and amazon, estate sales, garage sales etc.
Nov 24, 2008 | Craftsman Saws
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
