Question about Samsung AQV12JA Wall Mini Split Heat Pump
Turbo light keeps flashing when unit is not in use
Power and turbo light flashes when unit is not in use
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Flashing glow plug light no throttel just idle
This actuator is a very common problem for the Diesel Jaguar X-Type & S-Types Built between 2003 and 2007.
The fault causes the flashing glow plug light to appear and the engine to go in to "limp mode" the problem normally starts out as an intermittent fault but then becomes more permanent.
These Actuators control the waste-gate on your turbo and are not available separately from the dealer, you have to buy the complete turbo for a small fortune.
* I am not affiliated in any way with this company.
A company can rebuild your own turbo actuator and/or supply replacement units from stock when available both options come with an unlimited mileage Lifetime warranty*.
For more info or to Buy Now, please see:
Apr 09, 2014 | 2003 Jaguar X-Type
VW transporter 2.5 TDi auto glow plug light flashing & management light on
check the pipes to the exhaust pressure sensor for any leaks or blockage
Mar 29, 2013 | Motorsports
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
Flashing Light
maybe that light indicating the reading of the hdd.
Mar 14, 2010 | Acer Aspireā„¢ T180 PC Desktop
My unit don't work
my webcam is not work but light is glow so what can i do
May 17, 2008 | Quantum Q Flash T5dR Digital Flash Head...
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Samsung AQV12JA Wall Mini Split Heat Pump Logo
50 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
