Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
HOW TO INSTALL A WHEEL STOP ON A KENMORE PROGRESSIVE
The back wheels came off the vacuum cleaner and need tio fix this.HOW do I NSTALL A WHEEL STOP ON A KENMORE PROGRESSIVE
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
  • 10 Answers
SOURCE: Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Posted on Jan 14, 2009
wiringlunati
  • 576 Answers
SOURCE: kenmore progressive 360 vacuum cleaner has low
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Posted on Feb 28, 2010
heatman101
  • 43501 Answers
SOURCE: I HAVE A KENMORE PROGRESSIVE
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on Aug 21, 2010
  • 694 Answers
SOURCE: I forgot to put a bag in my kenmore vacuum
If the motor is running, there's a good possibility the fan is broken or worn down. This will result in no airflow. Solution? Replace the fan assembly or vacuum. I recommend a vacuum that won't run without a bag and has sturdier and multiple fans in the motor assembly.
Posted on Nov 18, 2010
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
How do you replace the wheel base on a t series windtunnel?
go to this web page and proceed:
http://www.ehow.com/how_6644661_replace-kenmore-vacuum-cleaner-belt.html
God bless you
Jun 19, 2012 | Vacuums
The beater bar on my Kenmore Progressive stopped turning. I tried to clean the hair out of it, then switched it back on. The bar still wasn't turning and then it started to smoke..... lots of smoke,...
The belt is broken.First while looking at the brushes,find the screws that hold that bottom plate on.Remove the screws and the plate comes off.This will allow you to lift the brush out of the vacuum.It is important to make note of how the brush fits in the vacuum.The new belt will fit on a groove on the brush.The other end fits on a small wheel about six inches back from the brush.
Thank you for using Fix Ya.
Jun 03, 2011 | Kenmore 27514 Bagged Canister Vacuum
I have a kenmore power-mate, 2 motor system vacuum and it's brush wheel is no longer spinning. I was in the middle of vacuuming when it suddenly started making a weaker sound, and I noticed the wheel had...
Depending on which model you have it could be a belt, brushroll and/or motor problem. Some models have hidden tabs that must be released after you have removed the screws to gain access to the brushroll.
Nov 11, 2017 | Kenmore 23612 Progressive PowerMate Bagged...
Wheel is sticking. I want to remove the wheel to clean the axel. kenmore 116.27514700
Thanks for the clarification. This is actually fairly simple to remove the rear wheel, however as you'll see after this has been removed, there really is no axle attached to this. It just snaps into the main canister housing. It may be that your wheel has broken, and a new wheel may fix your problem.
First here's a link to the parts shematic for your model so you can follow along:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11627514700&productCategoryId=0642000&brandId=0582&brandDescription=KENMORE&modelName=VACUUM-CLEANER&diagramPageId=00001&componentDescription=CANISTER&documentId=P0706048&blt=06
Simply put a flat head screw driver behind the brush, and pry it off. It will easily come right off. You may inspect the wheel, and the wheel housing that it snaps into to make sure there are no obstructions, or pet hair that are slowing the wheel down. Also look at the clips that hold the wheel in place to make sure there's no debris above the clips on the wheel that could slow down the brushes also.
If it all appears to be fine, you may spray some WD40 on the part of the wheel that spins, reinsert it back in the vacuum cleaner and test to see if that fixes it. If it didn't, you might just want to purchase a new wheel assembly.
Here's a link to the rear wheel for Kenmore canisters if you'd like to purchase a new one from our website:
http://www.govacuum.com/kenmore-panasonic-canister-rear-wheel-assembly-panasonic-part-ac99caktzv07-sears-part-4370702.html
Hopefully that helps you. If you have any questions about how to repair this, or other questions that I did not address, simply just add a comment as you did last time, and I'll be more then happy to answer any and all of your follow up questions.
If you found this repair helpful, please be so kind and rate my repair, or leave feedback. This is really appreciated, and one of the reasons that Fixya repair professionals continue to post free repair advice on Fixya.
Chris Jones
GoVacuum.com
Apr 27, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
My vaccuum has no more suction
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Feb 22, 2010 | Kenmore 31913 Progressive Direct Drive...
Wheels
The axle for the rear wheels have worn into the cut outs in the body that it goes through and they are rubbing on the wheel wells. This common for this vacuum model , the only real fix is to replace the body assembly. Sears will have to do this, this is NOT somthing you want to tackle by your self.
As for the machine locking upright that is the release lever and it just needs to be replaced.
Jul 16, 2008 | Kenmore 31913 Progressive Direct Drive...
How to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
Jul 14, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Beater bar
on the bottom take out 2 screws they are closer to the back wheels pull off cover there is a plastic cover over the beater bar take off there is a belt if it broke or wore out change the belt that should fix your problem
Jan 07, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
