Question about HP Photosmart D7360 Digital Photo Inkjet Printer - No Ink
How do i remove print head on hp photosmart d7360
SOURCE: HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Posted on Aug 04, 2008
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
joecoolvette
  • 5660 Answers
SOURCE: How do you open HP Photosmart D7360 Printer case?
Hold the bottom base of the printer with one hand, grasp the top cover under the HP logo, and pull upward with the other hand.
Posted on Aug 12, 2009
SOURCE: HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Posted on Oct 13, 2009
SOURCE: how to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Posted on Jul 26, 2010
No I see no solution noted here. again Photosmart D7360 error message 0xc18a0001 ink system failure.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Also this may help...
HP 145 Sequence HP D145 all-in-one printer
http://magicinkjetflush.com/images/PDF/HP_135_Sequence.pdf
or smaller file
http://magicinkjetflush.com/images/HP_135_Sequence.jpg
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | HP Photosmart D7360 All-In-One InkJet...
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
How to take apart HP photosmart D7360
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
How do you open HP Photosmart D7360 Printer case? We had a paper jam and part of the page ripped and we can't find it. I think it may be stuck under the print head.
Aug 12, 2009 | HP Photosmart D7160 InkJet Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7360
try to align the print cartridge. go to settings -> tools then choose align printer. you may also try to clean the print head.
Nov 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart D7360
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
try cleaning the cartridge contacts with alcohol and cotton swab.
Jan 16, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360 Digital Photo Inkjet Printer - No Ink Logo
53 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
