Ran out of oil purged system to release air already wont start
I left my home with the heat on, came home and realized I let it run out of oil agian....now last time somone just assisted me to purge the system of air to get started agian, so I did the same agian but when that worked last time this time dosen't seem to be doing the trick...?help? hoe do get my heat going agian....its intertherm make...and probably a model from around early 80s
    Scholar:
  • 144 Answers
Is the inline oil filter clean? When you get to the bottom there is a lot of sludge. This may have plugged either the filter or spray nozzle or both. I would change them regardless.
Posted on Jan 22, 2009
Furnace power has to turned off and on then it will start and run. Had to do this 2. Days in row now.
Oil burner? If so sounds like there was or is air bubble's in the in the system due to no oil in tank or a breach in the oil feed system (sucking air) . check your oil tank to see if it's empty, if full look for leaks around the filter and or air bleed screw on top of the oil filter housing. the furnace oil feed line will need to be purged of air at the pump with the bleeder screw. Call a heating repair man if you are not mechanically inclined but if you are try bleeding the system. here's a video of how you do it.
https://www.youtube.com/watch?v=gczmnT-FHJ0
Oct 13, 2016 | Heating & Cooling
No heat
Air pocket is trap in the cooling system..
Put you car onto a pair of oil change ramp / or steep hill with radiator cap off (when cold).
Look for air bubbles to purge for the system.
Jan 13, 2014 | 1995 Ford Crown Victoria
The Cool mode wont cool. It's just like fan mode. I cleaned all the dust off the panels and still wont blow cool air.
First the weather is extremely hot mid 90's and humid.I have a Trane combination a/c heat pump system. The A/C was pumping out warm air.I called for a technician and the problem was the compressor was not working.The solution/fix was to replace compressor start capacitor.The technician was here for about an hour.The compressor was running before he left however I informed him the air coming out of the a/c ducts after one hour of run time did not feel as cool as usual. It took from 1pm until 10 pm at night to cool the house air down to 80 degrees and the system ran constantly.I left it on 80 as that is where I usually leave it. Today again it is running all day barely able to keep the house at 80.My home was built in 07 block house, well insulated with thermal double pane insulated windows.I suggested to the tech to check the refrigerant level but he did not think it necessary and did not perform the check while here. The unit will cool the house down to 80 degrees but runs constantly.My question is: Should I have a technician come check out the system to insure proper refrigerant levels and pressure????????
Jul 30, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
ACTUALLY ITS A 2002 INTRIGUE,CAR OVERHEATED SHOP FIXED WATER PUMP AND THERMOSSTAT I DROVE IT HOME 10 MILES BY THE TIME I GOT HOME GAGE WENT TO 3/4 AND ENGINE STARTED MAKING A LOD POPPING NOISE THEY SAID...
if your mechanic would suggest taking the thermostat out i dont think to highly of him, i think after installing the waterpump they didnt purge the cooling system correctly, if you remove the thermostat your heater wont blow hot air and it may also cause your cooling system to run in an open loop and you will have them pesky lights on the dash driving you crazy, i would suggest having a different mechanic try to purge the system first
Jan 13, 2011 | 2000 Oldsmobile Intrigue
My new Laars JVS 225 boiler make a whining noise when heating up. It does it on all zones. This was a replacement for a Teledyne Larrs that had a leak but ran quiet. IPressure is 15 lbs and temp is 155...
My new Laars NeoTherm boiler (NTH150) was making a whining noise soon after install. The noise was audible through most of the home. Replacing the air/gas blower solved the problem. Correct sizing of pumps is also important to reduce (water-flow related) noise. Having done all that my Laars boiler still isn't particularly quiet in its start-up and (modulating) operation. It should NOT be located below or next to a bedroom.
Nov 19, 2010 | Heating & Cooling
Potterton statesman oil central heating boiler the household oil ran out and i had it refilled and now the lock out button is illuminated i believe i have to press the burner reset button but not sure...
Hello my name is Heath it will be my pleasure to assist you. You will have to push and hold the reset in on the side of the control for 15 seconds. But you will also have to bleed the air from the system from the 3/8 nipple on the lower left side once the lockout has been released and the motor starts.
Sep 05, 2010 | Heating & Cooling
My campbell and housfield 60 gal wont run.. help
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Feb 04, 2009 | Campbell Hausfeld 26 - Gallon Air...
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
