Question about Krups C75 Beertender Home Beer-tap System With Heineken Draughtkeg
Krups Beertender VB5028CT (C75) totally dead now.
I have a VB5028CT (C75) that went through various stages of dysfunction. For quite some time the display would be red indicating that the keg was empty, even when a new one was put in but everything else seemed to be fine so I left it alone. Then the unit stopped cooling and shortly thereafter (within 2 days) the display went out completely. The fan was still spinning but that's about it, so I unplugged for a few minutes to 'reset' it & plugged back in with no changes. Then I unplugged it over a weekend and when I plugged it back in there seemed to be no power going to it at all. Plugged it in one last time today and was able to intermittently see the fan spinning but not consistently. Any ideas? Other posts with these various stages have suggested replacing the capacitors, the peltier, and the PC board...do I need all 3? Any help in finding part #'s & sources and diagrams would be greatly appreciated!
I had one that appeared totally dead and replaced four capacitors (~$5 to buy) and it's back up and running. If you pull the back of the unit and remove the unit attached to the power cord you'll see a pcb board. Look for any capacitors that look kind of rounded on the top (they should be flat). On mine it was a cluster of one 470 uF and three 1000 uf capacitors. Desolder those and solder in new ones. Mine were rated at 16 volts but I replaced them with 25 volt units for a bit more safety margin.
Posted on Jan 14, 2013
3 Suggested Answers
  • 3 Answers
SOURCE: my beertender stopped cooling my keg. what can I
Wondering if you found a solution to this yet. Mine stopped cooling, too.
Posted on Nov 03, 2010
richroth
  • 9472 Answers
SOURCE: My krups beertender is not cooling
What is the model number?!
Posted on Nov 01, 2012
Krups b100 does not get cold enough. How do i fix this
Maybe the beer inside is cold enough to drink, but the green led that indicates it's ok, doesn't light on. So the thermostat may be not operating well or the ambient temperature is too hot. My beertender B100 is operating without turning compressor off. The compressor never stops operating... even when external temperature is under 26 C... but the beer temperature is ok.
Oct 04, 2013 | Krups VB2158001K BEERTENDER B100
Beertender wont turn on
You may have a problem with the starter on the unit. It will keep the unit from freezing or cooling.
Feb 03, 2013 | Krups BeerTender B95 Beverage Dispenser
I have owned a Krups Beertender for about two years. It has been working fine. The unit thermostat light turned red about 24+ hours ago and mains on. The fan is working. The beer is warmer than usual. ...
It could be the peltier or bad capacitors on the power supply.
http://www.fixya.com/support/t1554764-display_krups_beertender_stopped_working
If it is caps on power supply they are cheap.
Jul 21, 2012 | Krups BeerTender B95 Beverage Dispenser
I have a problem with a Krups Beertender model VB5020us. The indicator lights were blinking sporadically and it was not cooling. I removed the back and found that there are two circuit boards. One is...
If the lights are on/blinking, that usually means that the control board is OK, and it's the power supply that is not providing sufficient power for the cooling element to operate. This is a common issue with the Krups VB 5020 series.
Aug 17, 2011 | Krups BeerTender B95 Beverage Dispenser
Our Krups Beer Tender B95 display started flickering on and off. We turned it off by the switch and back on. It continued flickering. We then unpluggedf it. When we plugged it back in, it totally shut...
Your power supply has gone bad. Mine did the same thing. Sent it to repair place (under warrenty) and it has been 2 months and it is still not back. If you can find another beertender for 100 it is cheaper to buy another OR JUST TRASH IT!!!! Obviously this thing is junk as there and 100's of the same postings of this problem.. fafe it... we got ripped off. Sad because I really liked it... when it worked
Jan 30, 2011 | Krups BeerTender B95 Beverage Dispenser
My beertender stopped cooling my keg. what can I do to fix it?
Oct 03, 2010 | Krups BeerTender B95 Beverage Dispenser
WHERE CAN I PURCHASE A PELTIER FOR THE BEERTENDER?
I found mine on Ebay. for the price I bought two of them since they will fail. The part number is:
TEC1-12705 Thermoelectric Cooler Peltier 50W 77Wmax
Sep 20, 2010 | Krups BeerTender B95 Beverage Dispenser
Beertender freezes
the thermostat is not working right fit a new one,,,,
Aug 08, 2010 | Krups BeerTender B95 Beverage Dispenser
Display for Krups Beertender stopped working
unplug the unit for 30 seconds, then plug back in. I had this problem, and it is a solution to most modern electronic devices. it reboots the system.
Jan 17, 2009 | Coffee Makers & Espresso Machines
Krups C75 Beertender Home Beer-tap System With Heineken Draughtkeg Logo
186 people viewed this question
Top Krups Refrigerators Experts
Tom Chichester
Terry Hair
JonSnell Electronic
JonSnell Electronic
Are you a Krups Refrigerator Expert? Answer questions, earn points and help others
