I have paper jammed in my Duplo D-590 folding machine. How do I get it out?
SOURCE: Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Posted on Aug 18, 2008
DLBurkhart
  • 210 Answers
SOURCE: Magicolor 2300dl horizontal paper folding
I kept digging until I found some helpful, lucky people that stumbled across a solution. The cost of doing the repair yourself is about $1 for superglue.
I detailed the repair in my blog: http://dlburkhart.spaces.live.com/blog/cns!5BA5F950B86A8BE5!182.entry.
I don't know if that URL will work as a permanent link. So, just in case, the same information is on my business web site on the Tech Tips page: http://www.BurkhartTech.com/Tips.html.
I hope to have helped.
If anyone can use a custom web site, I can really use the work. I left work a couple of years ago to be a stay-at-home dad and to try to start up a web site business. Things started out okay. But the economy soured, all of my business dried up, and now I can't find full time employment.
Posted on Dec 15, 2008
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Posted on Jun 24, 2009
  • 199 Answers
SOURCE: Canon ip1800 will not feed paper...One side jams
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Posted on Jun 25, 2009
ajuhere81
  • 256 Answers
SOURCE: Epson print LQ-590 always paper jammed at roller
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Posted on Aug 21, 2009
Paper jam
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
Paper jam machine feedshift
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams.
May 24, 2013 | Toshiba E-Studio167 Copier
Duplo DF-520 N Manual
late, but...
try this one: http://downloads.udpnet.com/filedb/pafiledb.php?action=file&id=84
Mar 02, 2012 | Duplo Office Equipment & Supplies
The machine was jamming. I pulled the collator away from the base of the image runner. The paper was only 1/2 in the black box and 1/2 up the upper section that the paper goes through. After the paper...
I problem on duplo collator 10000s, is missfeeding the paper, don't pick the the paper, i set the correct hight, and **** pressure, i technician toll me that power supply need to repair , but i don't trust, just some one gime adviced
Oct 28, 2010 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
Our Pitney Bowes 1810 Folding Machine hums & the document dial for the folding style does not move! Help!
Problem is not fixed. It does not involve a fax machine, it involves a Pitney Bowes 1810 document folding machine. Not interested in paying for "service" - it appears as though your service would be of any help.
Thank you
Jan 26, 2009 | Office Equipment & Supplies
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
148 people viewed this question
k24674
jasbo
jasbo
