Question about Acer Aspire M3400 PC Desktop
How to reboot to default main hardrive - Acer Aspire M3400 PC Desktop
  • Acer Master
  • 27,725 Answers
Restart your computer during the boot process you will a certain key to press to enter set up usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press enter you will see the boot order Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? If you are unsure or have made mistakes you can load optimised or failsafe defaults this will automatically set the boot order Hope this helps.
Posted on Jan 11, 2013
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
While browsing my windows it automatically disappear and theres a clicking sound somewhere in the area oh hard drive and hen ever i turned it on there a something written and says " reboot and...
It can be many things. If the sound is clicking that is not good. Can you boot to windows? if you can i will describe you what to do then. The problem is that your os can't read boot to start your operating system. Try to hit del before start and set everything to safe defaults, and try again. When did this problem accured, did you install something , maybe remove some hard disk ? The data can be restored, if you have some other empty hard disk insert it inside , remove this that is clicking, install windows again on new hard, after all that insert bad hard disk bad, boot form new hardrive and you will se your old hard disk ( if it is recognized) if not go to computer management -> disk management and see is it listed there... send me some info so we can procide
Feb 25, 2011 | Computers & Internet
Does not recogizie a hard drive is insatlled. I b...
Ensure the sata power and data connections are set properly, then boot to the BIOS, reset factory defaults (If system has no floppy disk drive, turn it back off as resetting will enable it) then save settings and reboot.
May 20, 2010 | Dell Precision 370 (370TREC) PC Desktop
Hi all, I have problem because now i cant install my recovery CD even alt+f10 wont accept, like i didn't push those buttons. I have try to install some other XP cd and i got error like '' we can't find...
Under BIOS setting, set your hardrive to IDE instead of SATA, or use Win XP CD that contains Sata AHCI driver in order to recognize the hardrive.
May 04, 2010 | Acer Computers & Internet
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
I have a problem with hp dv9000.. the operating system wont boot.. even wen i insert any booting disk, it shows the first screen with hp and its logo and then it becomes blank.. i presume my harddisk is...
Try going to the bios and reset the bios to load factory defaults and then reboot. If the same thing happens try taking the hard drive out and reboot, if the same thing happens again its not your hardrive because it would say no boot disk after post. Iam guesing it may be a bios fault because after the logo it goes blank not while loading the os(operating system).
Give this a try and post back your findings.
Jan 20, 2010 | HP Pavilion dv9700t Notebook PC
Can't load xp on hp xw4300. Has sata hdd & ide dvd drive. Xp can't detect hard drive and if press f6 it says there is no floppy drive
replace your cables and try again. if unsuccessful locate your hardrives manufacturer ie: maxtor software MAXBLAST , download the hardrive software utility and ``0 fill`` your hardrive to factory default.
Nov 05, 2009 | Cars & Trucks
How do you reboot a acer aspire 9410-4317 notebook withiut a recovery disc .
turn on computer and immediately hold alt and press f10 until it goes to factory default screen. then chose to repartition. this will wipe your hardrive clean and reinstall windows
Aug 03, 2009 | Acer Aspire 9410-4317 Notebook
RE: EXTERNAL HARDRIVE..
Disconnect the USB drive
Boot to Safe Mode (F8 at boot), then open device manager (Right Click MY Computer, Properties, hardware tab, devicemanager button) then find the USB Root hubs and delete them
Reboot in the normal mode, go back to device manager, usb root hubs, right click each, properties, power management tab, uncheck the check box to let windows power off the hub (On by default)
reboot, connect drive, see if it detects.
If it doesn't. open Disk Management (Click Start, click Run, type compmgmt.msc, and then click OK.
In the console tree, click Disk Management. The Disk Management window appears) http://support.microsoft.com/kb/309000
and see if it is seen then but has a conflict with the drive letter.
If that doesn't resolve, try drive on another system.
Jun 24, 2008 | Computers & Internet
Acer Aspire M3400 PC Desktop Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
