Question about Bosch Dishwashers
Bosch lifestyle automatic dishwasher error e15 check water
Turned power off to try resetting with no luck. Checked water connection and all fine
3 Suggested Answers
  • 26 Answers
SOURCE: Bosch dishwasher not taking in water
May be open circuit water valve. Appliance will go to error mode if water level has not reached a certain height after a preset time. Check coil continuity with a multi meter. Should be looking for about 200 ohms.
Posted on Nov 12, 2008
SOURCE: I have a bosch dishwash e15 check water
I found this solution on elsewhere on fixya. it relates to a little float switch designed to detect water leaks I think. 1. turn off power and water 2. tilt back machine about 45% (have towels ready to soak up any spill off 3. when all the water has emptied, right machine and retry. if the problem keeps reoccurring, you may have a genuine water leak. I had to try a few times but this worked for me and saved me at least 4 days of hand washing over a long weekend. good luck
Posted on Oct 27, 2011
I have a Bosch dishwasher with a E15 error. This is triggered when the basin overflows due to the water not turning off during the fill cycle, overfilling the basin. E15 turns off the water filling.
There must be a bad switch on the water level float; if it were the valve, turning off the valve via the overflow switch wouldn't stop it either.
Apr 14, 2018 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
E15 i want reset it ?
If this is a Bosch dishwasher, the E15 error indicates water in the base of the unit. You need to unplug the dishwasher and pull it out (if it is an under-counter unit) carefully. Empty the water from the base. Sometimes tipping the unit so that the base is tilted 45 degrees from the floor will help the water flow out. Make sure that the entire base is dry.
Replace the dishwasher under the cabinet (if needed) and plug it back in. If the error repeats at the next cycle, you need to determine where the dishwasher is leaking. It could be the outlet hose, the pump or the tub. Replace the bad part. If the dishwasher is under warranty, contact Bosch.
I hope this helps.
(if you recently had a flood either under the kitchen sink or an overflow at that sink, you just need to dry the dishwasher base.)
Apr 16, 2015 | Dishwashers
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch diswasher e15 light
Most likely it is the flood switch trigger causing the problem.
Many reasons for this but mainly it means there could be water leaked into the base of dishwasher where flood switch is located.
Or if you have Aquastop fitted in the water inlet hose then the hose might have kinked due to age or being pressed between cabinet wall and dishwasher. Turn power off to dishwasher at mains plug and pull it out. Check hoses. Tilt it about 20 degrees to one side on a towel and hold for about 10 secs. This should get the water out. Wait an hour or so to dry any moisture in the base and then plug back in and turn on. This should reset the E15 fault.
Apr 21, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Alarm e15 up and can't reset
Bosch SMS Series Dishwasher Fault Codes E15
Water in base
Float sensor in the base has been activated. You can try to empty the base and restart the dishwasher as you will find noted many times in the forums but, if there is a leak this error code will simply be displayed again, you must find the cause of the leak.
but if you have a different model it can be something else
Dec 26, 2013 | Bosch Dishwashers
E:15 code is stuck on display. How do I reset?
E15 means that unit doesn't think it's getting water. Make sure the water to the unit under your sink is turned on and the dishwasher is getting water. If so then start a cycle and wait until the error occurs. If there is not water inside the tub then you have a problem with your electronic water valve and will need to have it replaced. If you do have water inside but it's still giving you the error, then you have a bad flow meter that iwll need to be replaced.
Jun 10, 2010 | Bosch Integra 800 SHX68M0xUC Dishwasher
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Mar 18, 2010 | Bosch Dishwashers
Nov 11, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
268 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
