Question about Admiral Dryers
Running then just shut off - Admiral Dryers
  • Admiral Master
  • 8,220 Answers
Thermal limit tripped due to bad blower wheel is what goes down on these. Blower wheel need to be checked for looseness and dryer vent needs to be cleaned if that is the case
Posted on Jan 11, 2013
If the hydrant runs it wont shut off.if it shut off it will not run.can not get it adjusted to run and shut off at the same time.
Your question imposes an enigma! Can you be more clear. OFF should be OFF and ON should be RUN
Apr 25, 2016 | Air Tools & Compressors
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Runs but shuts off automatac
check the oil, most of these have a low oil shut down. If it's full make sure it's sitting level while running. If it still shuts down and is full of oil and level, bypass the low oil shutoff and see if it stays running.
Dec 04, 2012 | Coleman Powermate Premium Plus 6250W...
Computer shutting off
shutting off when? Shutting off immediately when you try to start it? Shutting off after it has run for a while?
If it is shutting off after it has run for a while, then it is probably running hot. If you try to restart it immediately it will not boot. If you let it cool off for a while then it will boot successfully (definitely a sign of running hot).
Things that make a computer run hot:
1) Dust in the vents, fans, cpu & heat sink and all inside the computer.
2) Fan not working
3) The Thermal Paste on the cpu and heat sink has either dried up or is too thin to keep it cool.
If it shuts down immediately after it has been sitting for a while then it's not running not and your system has some other problem.
Mar 31, 2012 | Computers & Internet
Hi guys I have a Toshiba Laptop Model TE2300 on shut down a screen comes up saying END PROGRAM- SAMPLE this stops you shutting down what is the problem and can it be fixed thankyou Kind Regards Mark
the end programs means that some program is running while you are shutting down you have close all the program before shutting down you can just click end program or wit for the process to end by itself to know which program is running while you close press CTRL+ALT+DEl click the file you will see the program which are running go to shut down and click shut down its shut downs and the end program stops coming
Nov 14, 2010 | Toshiba Tecra TE2300 Notebook
Boots up windows runs for 5 mins then system shuts
You may have a cooling problem (with older computers), if you hear your fan running excessively and then it shuts down on you. Otherwise it is more likely a hard drive issue.
Jan 25, 2010 | Toshiba Satellite P25-S5263 Notebook
Chainsaw will run but will not shut off with the run/stop switch
The cut off wire is probably broken before the switch. Depending on the make,you'll need to remove the pull start housing to fix it.
Jul 15, 2009 | Garden
When we shut off tv for the day the fan motor continues to run it does not turn off
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
May 23, 2009 | Televison & Video
Dryers Logo
57 people viewed this question
Top Admiral Dryers Experts
gbob59
Sal De
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
