Question about Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator
Water Dispenser The ice maker/dispenser works fine, but the water dispenser does not. When I press the actuator the light comes on and I can hear a motor running.
  • 7 more comments
  • Patrick Markey Jul 14, 2007
    Turns out that the water hose inside the freezer door was frozen. Hot water was the cure.
  • Patrick Markey Nov 17, 2007
    Every time I've used the extra-ice button the water hose in the freezer door froze.
  • bogtrotter Jan 18, 2008
    is there some sort o solenoid in the water dispenser section.
    i have no water flow. the water tank if fine and there is water getting to the pump at the back.
    when i press the dispenser lever there is no sound of any pump etc operating
  • Anonymous Feb 10, 2008
    Water dispenser will not work. The light works but the dispenser does not. When pressing the water dispenser you can hear the motor running but no water. The ice maker is in the freezer not the dispenser. The ice maker is working fine.
  • Stringer1 Feb 10, 2008
    Wow! It took about 10 minutes to fix the dispenser problem. Thanks! It works just fine now. I took the hair dryer to defrost the line. Great site to come to.
  • suzie71 Feb 19, 2008
    I have the same problem. How did you get the water line to unfreeze?
  • Anonymous Mar 12, 2014
    It is 5 years old. Ice maker works fine
    When I push water dispenser paddle no water comes out!
  • Anonymous Mar 24, 2014
    I have a Frigidaire side by side refrigerator (model FRS6HR35KWO) that has suddenly stop dispensing water. The problem seem to occur between Friday and Sunday because the last time I used the water dispenser (the previous Thursday, it worked fine). Because there was no water coming out, I thought it was a filter issue (the refrigerator doesn't have a filter light) so I replaced it. The water dispenser still doesn't work. I can hear the water inside the refrigerator moving and my hose moving about behind the refrigerator as it always does but the water is not reaching the outside door dispenser. When I remove the filter from the inside of the refrigerator and press the water dispenser lever on the door, the water dispenses inside the refrigerator (where the filter would be attached) with no problem. Once I put the filter back on and try to dispense water, I can hear it working but no water comes out. I'm using a Frigidaire Pure Source filter RG-100. I've used this filter for years and haven't had a problem before.
  • 32 Answers
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Posted on Jul 04, 2007
3 Suggested Answers
SOURCE:
  • 58 Answers
SOURCE: water dispenser quit.ice maker works fine you can
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Posted on Sep 16, 2010
  • 16 Answers
SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Posted on Jan 23, 2009
Hi, I have a amana af12538aes french door refrig. Starting this am, the control on the door does not deliver ice only cold water from the ice button. The ice maker is making ice. Is this a control...
Is the display flashing when you try and use it or can you hear the dispenser door opening and closing rapidly (clicking or clapping sound)? These are prone to the board going bad and losing the dispenser. Is the "ice" light lit on the dispenser? The touch pad could be bad too. Do you hear the auger motor turning the ice when you press the dispenser? or just the "shhhhhhh" of the water coming out?
If there is ice in the bucket then that is not the problem. Dump it and listen if you hear new ice drop to verify.
There is no such part called an "ice element". Ice maker-yes.. Heating element-yes.. Ice dispenser-yes
Mar 04, 2018 | Amana AFD2535DES French Door Refrigerator
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Water at door stopped working. water still comes to ice maker. no damage to electronics panel. Ice dispenser, whole and crushed works fine. is there a relay in the water circuit that fails? Or, is a...
I have the exact same problem. Ice maker works but nothing at the water dispenser. The light come on when I press the lever and I hear a click. But nothing like water "trying" to be pumped. I am nervous it is more than just a frozen water line. Anyone else have this problem or a solution?
Dec 09, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice maker dispencer motor won't spin. You can hear a click, and the ice dispenser light dims. The water dispenser works fine.
Best solution is to replace the ice maker. The ice makers are a cheap item and very hard to work on. It is easier to replace the ice maker rather than trying to take it a part and replaced the motor or gears. If you do want to take on the project you have to remove the ice maker and check the gears for a worn spot and the motor to see if it is still running. Parts can be purchased at a local appliance dealer. In tulsa we have Greers appliuances.
Nov 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Samsung RS253BABB. Where is the water pump??? I press the switch for the water dispenser and I can hear the pump running but no water comes out. The ice maker works so its getting water to the unit through...
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 21, 2009 | Samsung SRS20DTD Side by Side Refrigerator
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker
PLEASE CLARIFY THE TERMS "MOTOR", "ICE MAKER SWITCH" AND "ICE TO COME OUT"
FAN MOTOR? COMPRESSOR? AUGER MOTOR?
ICE MAKER ON/OFF SWITCH? DISPENSE SWITCH? DOOR LIGHT SWITCH?
ICE TO COME OUT OF THE ICE MAKER? ICE TO COME OUT OF THE DISPENSER? ICE TO COME OUT OF BIN?
Feb 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Logo
2,061 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
