Question about Tacktick Micro Compass
Compass turns off by itself even though battery is fully charged with 200hrs.
It happens mainly when the shadow of the boom passes over the top of the compass. We sail in the Caribbean with bright sun.
My 2000 BMW Z3 Roadster completely shutdown. Nothing works even though the battery is fully charged. What can I do to remedy this problem?
Well you have some power. So I would check grounds first. Main three are the battery to engine, battery to body and engine to body.
Jul 25, 2015 | BMW Cars & Trucks
I have a Advent 8315 the turns itself off when unplugged even when its fully charged
Try removing your battery, wait 30 seconds and plug it back in and see if it powers up. If not, take your battery out, put it in the freezer overnight, take it out and let it sit in room temperature for 12 hours and then put it back in ....DO NOT put it in right out of the freezer and into the laptop ...let it warm up .... after 12 hours, try it and see if it shows 0% and charging ...if it still shows 100% charged, your battery is shot. Let me know how it goes
Mar 16, 2014 | Advent Computers & Internet
1984 Honda shadow 500 won't start.
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 Honda Shadow VT500 Won start
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Apr 21, 2013 | 1984 Honda VT 500 C Shadow
Camera will not turn on even though batteries are not fully charged
What happens when you fully charge the batteries? And by the way, what make and model camera?
Nov 28, 2012 | Cameras
2005 Honda VT 750 Shadow Aero will not turn over
Hi, James before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
2000 Honda Shadow Ace 750 Wont Start Turn over at all
What to do When Your Motorcycle Won Start
Honda VT750C2 Shadow Spirit Service Manual
Honda VT750C2 Owner Manual
Jun 01, 2017 | 2005 Honda VT 750 Shadow Aero
I was to advised to charge a new battery only 2 to
Two to three hours should fully charge your battery, to porlong battery life I would let the battery run as low as possible before recharging. Recharging half charged batteries causes the battery to age faster.
Oct 27, 2009 | Cell Phones
Battery meter is low, even though computer is always plugged in
Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
Oct 07, 2009 | Acer Aspire 6920 Notebook PC
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Psp won't stay on
How do you know the battery is fully charged ? Repeat this operation with someone else's battery and see what happens...
Nov 30, 2008 | Sony PlayStation Portable (PSP) Console
Tacktick Micro Compass Logo
232 people viewed this question
Top Tacktick Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Tacktick Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
