Question about Miller 903777012 SPECTRUM 2050 PLASMA CUTTER
Miller 2050 plasma press alert
When I turn on machine I get power and ready lite. Then 2 1/2 seconds later ready lite goes out and press alert comes on. I have correct press thru regulator to solenoid and the press switch ohms out as closed above 40 psi. Since I have two 2050s, I swapped the 4 PC boards(2 on each side) as well as the torch/hose assembly and still have same symptoms. Any suggestions as what to try next? Tom
4 Suggested Answers
johnr1959
  • 56 Answers
SOURCE: miller 3080 plasma ,won't fire
check groun dconnection on workpiece and where connected to machine>> check reset switch.>
There is a screw in fuse on the back make shure you unplug the machine befor removing any fuse or working on any electrical problem.>>OUCH!
Posted on Jan 29, 2009
  • 24 Answers
SOURCE: Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Posted on Sep 18, 2009
SOURCE: how much does a circuit board cost for a miller
depend the circuit boar but is be twin 500 and 700 usd
Posted on Feb 08, 2011
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
It runs when u press the trigger theres no fire or air comes out
Is the compressed air pressure in the limits for the unit to work. try turning the pressure up.
Aug 01, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
It runs but when you press tha trigger theres no
go to miller.com they have downloads for most everything they make. it sounds like you might have a ground problem or a bad connection in the tip
Jan 24, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Power light blinking fast and voltage is fluctuating on load side of system and no power to handle
The machines that I have seen do that need the main circuit control card assembly. It is not a cheap circuit board either.
Jul 15, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Miller 3080 plasma ,won't fire
Jan 14, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Oct 15, 2008 | Philips 42FD9932 42 in. Plasma Television
Miller 903777012 SPECTRUM 2050 PLASMA CUTTER Logo
53 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
