Question about Philips 32PFL5403D/27 32 in. LCD TV
User manual In and out HDMI ports
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
How do I find the HDMI port on a Vizio HDMI HDTV?
A model number would be helpful...
The Vizio website is very helpful and has user manual available.
VIZIO Product Support and Services VIZIO
Aug 03, 2014 | Vizio Televison & Video
Where is HDMI Connection?
look at your user`s manual if your unit have that features,then look in manual where is tha exact location of hdmi port...but mostly it is covered with small folding cover.if you notice some small covered on top or some where at the side
Jan 26, 2014 | Norcent Technologies2703 27" TV
Unable to Connect Laptop to Samsung LED TV
VGA is analog - HDMI is digital
if u have a cable w/o a converter it won't work unless your video card supports digital signal output through VGA port function. Please consult with your laptop's user manual for more information.
Dec 10, 2013 | Compaq Presario Notebook
Toshiba satellite C855D-S5105 HDMI
For the Toshiba Satellite C855D-S5105, HDMI is an option.
If present, believe it to be on the Left side, same as the VGA port.
[General example of VGA connector (Port), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Note* Color is not always Blue. Scroll down a little for VGA Cable example ]
User Manual states plug external monitor device into laptop, then turn external monitor device on.
External monitor device should automatically be seen by laptop.
If not press, and hold down on the Fn key, and at the same time, tap on the F4 key until the display option you want is shown. Then press the Enter key.
Touchscreen?
That requires a knowledge of Windows 8, which I do not have a full understanding of yet. The User Interface of Windows 8.
It isn't stated by Toshiba, (At least that I could find), as to if the HDMI port; is just that. An HDMI port, or a Mini-Port HDMI port,
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
There are HDMI adapters, and HDMI cables; that adapt from regular HDMI to Mini-Port HDMI.
There are adapters that connect to a VGA port, and convert to an HDMI port.
Not the answers you are seeking? Please reply in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 12, 2013 | Toshiba Computers & Internet
PDP 435HDG HDMI selection
Do a factory reset to this set and proceed. Refer its user manual for details.
Jun 05, 2012 | Pioneer Pdp-4360hd 43 Purevision...
I HAVECONNECTED ALL MY SPEAKER WIRES,HDMI CABLEAND CONNECTED THE YELLOW AUDIO CABLE.POWERED UP THE DVD BOX BUT I ONLY GET SOUND FROM TV.the tv is a new 47'' LG.
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
Jan 01, 2011 | Televison & Video
How to connect 5 way speaker with lg plazma
use LG HT5xxTH series Home Theatre systems to your TV, if it supports HDMI. Search your user manual to see if has an HDMI port
Jan 09, 2009 | Computers & Internet
Philips 32PFL5403D/27 32 in. LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
