Question about Acer Aspire 5602WLMI Notebook
NOW COMES UP WITH PARITY CHECK 2
AFTER BOOTING IT SHOW PARITY CHECK 2
  • Acer Master
  • 7,627 Answers
Reseat Memory Mods. May be a Memory failure.
Posted on Jan 12, 2013
What causes memory parody error?
Not memory PARITY error?
[1]: PARITY is a self-check that the computer does to make sure it is still talking the correct binary language, eg 0110100...
[2]: Each byte addressed to RAM also receives a 'parity' bit.
[3]: The processor calculates this parity bit with the data.
[4]: If the computer sees that the data it expects too see does not match with what it sees then what the user sees is the message that you have seen.
[5]: See?
Nov 17, 2017 | Computers & Internet
Parity check
This is ith the RAM in the omputerin the giving you thqt defect. replae the RAM and it will fix the problem.
May 04, 2013 | HP Computers & Internet
SCREEN SHOW PARITY CHECK 2
Might be DIMM (memory) number 2 going bad.
Jan 11, 2013 | Acer Aspire 5602WLMI Notebook
Ram damage
The 2 beeps indicate a ram parity error. Remove the ram and clean the gold contacts with a pink pencil eraser to make them nice and shiny again. If you still get the ram errors, try booting with only one stick of ram at a time and you may be able to determine which dimm is the problem. Make sure the time is set correctly in the bios, and make sure you have set the correct time zone in windows. Let me know if this helps or not.
-Joe
Apr 17, 2012 | Fujitsu Siemens Computers & Internet
Just powering on my new ASUS M4A88T-V EVO Motherboard to check if I have my connections done right, Receiving two short beeps then no beeps, Trying to find out what that means
2 Beeps? maybe Parity circuit failure
it is responsible for generating and checking the parity bit on the system memory when parity checking is used. This circuitry is not working properly.
This code usually means a problem with either the system memory or the motherboard.
Try to reset the cmos remove the battery. if not check the memory,try clean the gold surface of the memory using pencil eraser.
Sep 23, 2011 | ASUS M4A88TV EVOUSB3 Motherboard
Twice beep sound is coming. Booting is not happening for my p4p800 mx/s board
Hello !
If you check out ASUS support, you will find this troubleshooter for the motherboard not booting :
1. Please clear CMOS.
2. Please take out your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Please take the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Please keep the necessary components(CPU, one memory) onboard for a test.
Finally, we would recommend you to replace a BIOS battery to have a test.
Also, by looking over beep codes I have found for AMI BIOS these problems for the 2 short beeps :
1. Memory parity error (Description : A memory parity error has occured in the first 64 KB of RAM. The RAM IC is probably bad).
2. POST fail (Description : One of the hardware tests have failed).
If you have done those and it still doesn't boot, let me know I'll try to find other solutions.
All the best !
Aug 03, 2011 | ASUS P4P800-MX Motherboard
In my IBM X226 server 2 HDD became unavailable in RAID 5 configuration. now I have replaced the hard disks and rebuild process is continuing. 1962 operating system not found error message is being shown...
Raid level 5 gives you some redundancy in your raid however it only allows you to lose one hard drive, two hdd lost would not permit to recover from. the parity bit can rebuild one hard drive but not two, sorry your raid might be lost
Aug 15, 2010 | IBM xSeries 226 Server
2 SHORT BEEP AND 6 BEEPS ON BOOT Asus NCLV-D motherboard
2 short = Parity circuit failure 6 beeps = Keyboard controller Gate A20 error
make sure all hardware is installed properly
retrace your connections to insure all parts
were installed correctly. you may have to disconnect and start from the
beginnig to correct this problem. disconnect all unneccesary prephrial
leave only the mouse /keyboard and monitor hooked up and try booting again . eliminate as you go to narrow down to the problem.
Nov 12, 2009 | ASUS NCLV-D Motherboard
1 Adaptec RAID 3085 cause parity error in server while 2nd don't!
I'm thinking you should be checking the drives. If one of them is failing, you will get parity errors.
Picking apart parity problems TechRepublic
Mar 04, 2017 | Acer Altos G530 Server
Hardware malfunction
HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED
Dec 07, 2007 | Dell Inspiron 6400 Notebook
Acer Aspire 5602WLMI Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
