Question about Refrigerators
Tfx25ppbb fan not turning - Refrigerators
  • 17,129 Answers
Possible that the fan has failed, check the power at the pin connector to the fan while the fridge works, if present the fan is faulty.
Posted on Jan 12, 2013
Testimonial: "Fan did fail. By placing an ordinary box fan behind the fridge I was able to supply air flow which saved all the food in the freezer. I ordered replacement fan motor but I know this will solve the problem since the fan worked."
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
Fan barely turns
If the fan is barely turning, it could be the fan is bad. This fan blows air across a 2 coils.
May 29, 2014 | Haier HD456 Dehumidifier
GE Performance Profile TFX25PPBB Freezer Defrosting
you may have a fault you may not. if the fridge is ok then the freezer is going through an automatic cycle. If the freezer is not working then the fridge will soon follow.
likely faults causing this are; thermistors; worn out compressor motor; degassed compressor/receiver (can become hot and sluggish if lost gas/lubricant mix; dirt around the fan maybe causing it to be sluggish too. make sure you unplug it before touching anything!
Jan 11, 2013 | Refrigerators
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
My coolant is not working? when driveing it stays cool but as soon as i stop the fan dosnot kick in ad i over heat?
The coolant is working well, because the engine stays cool while driving. The problem is the fan relay, fuse, or the fan itself. Do you have AC? If so, turn it on and you should have instant running of the fan. The normal operation of the fan is: the engine thermal sensor tells the computer that it is getting hot which in turn tells the fan relay to turn on and that is supposed to turn on the fan itself. The fuse protects the high current wire to the fan. Try to turn the fan blades by hand--if stuck or very hard to turn, replace the fan motor. If you can't find the fan relay in the fuse compartment, it may be a solid-state device that is located near the fan motor. Chase the fan wiring back to the relay. Hope this helps!
Apr 30, 2010 | 1999 Jeep Grand Cherokee
Rad fan makes car shake 2003 sunfire
I would check the radiator fan in the car for looseness. If the fan wobbles or moves , Then change out the radiator fan. The radiator fan and motor come as one piece. There is a fan relay also should be replaced.
When turning the key only half way to make the dash fan work, indicates that the dash fan is okay.
The dash fan may make a whining or high pitch noise when engage. Then I would change it out because an internal bearing to the fan is going out.
Good luck
Mar 18, 2009 | 2003 Pontiac Sunfire
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
