Question about Destroyit 2604CC Shredder
On the destryit 2604 the door open light stays on even when the door is closed and the machine will not run
How do I know the door switch is bad
If light stays on when fully closed, door switch needs replacement, easily removed. Short term fix, disconnect the switch and tape the two spades together. Warning! Dryer will run even with door open.
Nov 29, 2014 | Sears Kenmore Elite Electric Dryer 69278
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
It seems that even with the doors and the hatch closed, the light stays on and the open door light is on. Not sure why
Did you check the glass panel in the hatch was closed properly? I've inadvertently opened it (while trying to open the hatch) and forgot to close it properly, thus keeping the open door light on.
Dec 31, 2010 | 2004 Mazda Tribute
Door is closed and the light stays on. after a while non of the buttons will work any suggestions.
I have the same problem but my interior drum light stays on whether door is open or closed; in either case the control panel becomes in-operable after about five minutes. I unplug the machine for 5 to 20 minutes then plug it back in and it is powered "on" the moment I plug it in (i don't even have to push the power button). Then the light remains on but i am able to operate the control panel so i can do a load of clothes. Then if the machine sits idle for no more than five minutes, the control panel becomes in-operable again and the interior drum light stays on.
Any one have a clue???
Nov 09, 2010 | LG WM2501H Front Load Stacked Washer/...
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Interior Light sometimes will not shut off in Ford Ranger Pick up
If I am not mistaken, the plunger is located in the door with the latch. Most of the time you can just pull the door panel off and adjust the switch. After opening and closing the door, they get knocked out of adjustment. I sincerely hope that this helped you. Take care and best wishes.
Bryon
Mar 20, 2009 | 1997 Ford Ranger SuperCab
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
Destroyit 2604CC Shredder Logo
32 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
