Question about Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher flashing pots and pans heavy wash mod#d3251
Unit works 5-10 min after stop and flashing pots and pans heavy wash
2 Suggested Answers
  • 534 Answers
SOURCE: I have an ASKO D3251 that is not draining. We
You will need to remove the bottom panel of the unit below the door that exposess the motor and the electrical along with water hook up. Now you will nee to manually go through the cylces (or let the machine cycle) to rinse. Once in the rinse cycle you should have heard the selinoid activate to drain the water. This selinoid click and pulls an arm down when in drain mode if you are looking under the unit you will either hear it or see this activate. If not then the selinoid is out, if you hear it activat then you need to look at the back of the motor to see if the motor itself is turning. You should be able to see the fins on the back of the motor turn once it goes into drain cycle. If you do not see the motor fins turning (you have to look through the vent slots located on the back of the motor) you acan take a small slotted head screwdriver and with the power off, you can insert this screwdriver into the vent holes in the back of the motor to spin (or move) the motor fins. If they do not move freely then the motor itself is froze up in that case a new one is needed. If the spin then try your drain cycle again since you may have unfroze the drain motor.
Good luck hope this helped
Dave
Posted on Feb 02, 2010
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
I have an asko d3251 dishwasher that won't stop running. The device in the drain that spins won't stop. I had to shut the power off to the unit.
Our unit had leaking connection on outlet side of fill solenoid valve. Any leak will cause water to accumulate in base pan. there is a float switch in base pan as a safety mechanism when water is in pan it causes a styrofoam float to rise and make contact with switch. This tells machine there is a leak creates error code to run pump continuously until water is removed from base. Disconnet electric from unit first. you must pull dishwasher out to get at back panel. Remove lower back panel to get access to mechanicals of unit. Once you remove panel you should see water in pan. If you see water that is most likely same issue we had. soak up excess water or tilt unit to drain water out of pan. once water is gone unit should start normally. If you look underneath while unit starts up - don't touch anything while unit is connected to electricity! You should notice where water is coming from. Our unit leaked at hose connection from outlet side of solenoid fill valve. connector is a plastic cam-lock fitting with a flow sensor integrated into it. there is an o-ring between the two parts. it comes apart with a very small amount of counter-clockwise motion. perhaps only five or ten degrees of indexing and it falls right off. it is a very flimsy connection for the main water line. the o-ring on our unit Was slightly deformed and not seated correctly. could have been from original installers 4 years earlier! Asko needs to re-design this part. I replaced o-ring and unit is working again however I do not trust that this fitting will hold up over time. Very poor design in my opinion. Other design flaw I noticed while looking at mechanicals is circulating pump isolation mount is not in correct location for pump motor. rubber mount is stressed to the point of almost tearing off! No way for me to correct this since location of mount does not match position of motor. We will not replace this unit with another ASKO when it goes.
Jan 19, 2013 | Asko D3251HDSS Stainless Steel Built-in...
Asko dishwasher heavy wash light flashing and pump continually drains even with door open
The reason our Asko D3250 had this problem was because of a leak. The pump hose (approx. 2" black rubber hose - find it here http://www.repairclinic.com/PartDetail/Pump-Hose/8801409/1810263) was split, causing a leak and the blinking heavy wash light. The sensor did its job and picked up the leak.
If you're handy you don't necessarily need to call a repairman in to accomplish the work. You don't need to pull the front of the dishwasher apart. Unplug the power to the dishwasher. Take off the back bottom panel. Next, test where the leak is coming from. Place pans below the holes found on the bottom of the dishwasher. They are visible when removing the back panel and are most likely at the rear of the dishwasher. Plug the power back in then start the dishwasher. If your problem is a leak, you will easily spot it with a flashlight. After ordering and installing your part, make sure to dry all water that has settled in the bottom of the dishwasher. You can easily accomplish this through the back of the dishwasher with the panel removed. If it's still damp the sensor will continue to detect water. Once dry, start the cycle to make sure there are no more leaks before reinstalling the panel.
Aug 09, 2012 | Asko 24 in. D3250 Built-in Dishwasher
I have an ASKO D3251. Door free falls when opened. No longer has tension to control downward movement.
Your springs are faulty.you have two of them and will need to pull the unit out and inspect.usually on asko dishwasher you have to order the whole tension spring assembly .
Jul 29, 2012 | Asko 24 in. D3250 Built-in Dishwasher
Hi, I have an ASKO D3250 dishwasher and it keeps stopping during the wash cycle and flashing the heavy pots and pots symbol simultaneously. I tried cleaning the filter basket and found a little plastic...
The part is a cap for the drain pump. You can put it back into position by removing the filters and placing it to the left of where the circular filter would be positioned. The part goes in with the part numbers on the bottom facing down. When positioned it should not interfere with the threads for the circular filter. You may have to scoop out the water in the bottom, to have a better look at how it is positioned. It is always normal to have a little bit of water in the bottom filter area (below the silver screen filter).
Oct 18, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Dave
Feb 02, 2010 | Asko D3251HDSS Stainless Steel Built-in...
ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Blinking lights on Front Panel
I've finally tracked down the manual and it the fault code is as follows
"Indicates a fault in the heater or in the thermistor"
You can go into a fault tracing mode by pushing the "Rinse Hold" button five times within 15 seconds. The first, third, fifth and seventh lights will flash when in this mode and you can test the following parts by pressing the corresponding button. I'm going to try the heater test below and assume that if that works the fault must be with the Thermistor. The other tests could be useful for other faults.
User manual found here
Rinse Hold - tests detergent solenoid, detergent flaps open after about 60sec
Pots & Pans - tests Rinse Aid Solenoid, rinse aid will flow down door
Normal Wash - tests water inlet valve, water can be heard entering
Light Wash - tests ventilator solenoid, there will be a click followed by a rattling noise
Quick Wash - tests the heater, the element heats up, WARNING don’t touch element HOT
Temp - tests circulation pump, the pump starts
Dry - test outlet pump, the pump starts
Manual says to push 55 and 65 degree button to exit, I have no idea where those are so will probably just switch off at wall to reset.
Hope this helps someone. I rang ASKO and they said they didn’t know what the fault code meant so either they can’t read or their service sucks, probably a bit of both!
Feb 12, 2009 | Asko D1716 Built-in Dishwasher
Asko D1876 dishwasher
the dishwasher remembers how long the last wash took.was it intterupted? try using again, or the board could be faulty it should be about 2hrs 10 min approx.hope this helps
Mar 16, 2008 | Asko D1876 Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
361 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
