Question about Muratec 2nd 500 Sheet Letter/legal Paper Tray Feed Unit Mfx-c2500 In Box
How to reset roller 2 on muratek mfx-c2500
Need to reset tray 2 roller counter
2 Suggested Answers
  • 1218 Answers
SOURCE: reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Posted on May 27, 2010
How do I replace PF kit1 Brother MFC-8460n
The paper feed kit is the pick up rollers and the transfer rollers. You can thake those out clean them and replace them, but unless you are actually having paper feed issues usually just clean the paper tray feed rollers with alcohol and reset the paper feed kit counter if needed.
May 21, 2014 | Brother MFC-8460N All-In-One Printer
Reset counter
not enough info, please describe which counter, and do you need to reset it or the machine ask for reset ?
Dec 07, 2013 | Ricoh Aficio Mp C2500 Copier
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
How to reset counter on canon dr 7580
You need to run Qumatool to reset the counter
S. Mohan
Oct 14, 2011 | Canon DR-7580
Misfeed in tray one with no misfed paper. The machine is trying to grad from tray one but cant.
Pull out your paper tray (instructions below) and make sure there's not paper behind the tray blocking the motors from operating.
Else, worn rollers or broken lift motor.
First go to the service sim mode with the key combo # * C *
Type 22 - Start 9 - Start
If your tray 1 counter is above 100,000 your 3 rollers need to be changed. This is easily done by taking out the tray (you must tilt to the left and lift up at the end), unclipping and removing the paper guide, and unclipping and removing the 3 paper tires.
If your counter is under 100K try washing your rollers with soap and water, rubber cleaner and alcohol if you have it, but not Windex or 409. Your matched set of feed/sep tires should have some rough tread on them, if they are baby **** smooth its' replacement time.
If it pulls paper from a fresh stack and then stops pulling after a few sheets, the motor that continunally lifts the paper stack to meet the rollers has broken down, and can be replaced from the back of the machine.
Dec 30, 2010 | Sharp MX-3501N All-In-One Printer
How to replace the PF roller on a brother DCP 8065
1.Pull out the paper tray
2.turn the machine upside down
3.push the blue lift arm and pull out the pin of the PF roller
4.then slide the PF roller to the left and pull it out
5.replace it with new one put the pin of the new roller into the hole of the blue lift arm.
6. place the machine on its base.
P.S you need reset pf roller counter after replacement
press "MENU - START - 088"
LCD shows "PARTS REPLACEMENT"
go down with arrow till "reset PF kit T1?" PRESS "SET" key
all done.
Jan 31, 2010 | Brother DCP-8065DN Laser Printer
Where can i find document rollers for document feeder?
document rollers is located immediately beside entering the paper or on paper if you use presenting with pallet
Oct 08, 2009 | Muratec MFX-1430 Copier
Reset drum counter on a muratec mfx 1430
Sep 15, 2009 | Muratec MFX-1430 Copier
Muratec 2nd 500 Sheet Letter/legal Paper Tray Feed Unit Mfx-c2500 In Box Logo
23 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
