Question about Shindaiwa N452
Need to know proper fuel mix for shindaiwa homepro n452
Do I mix the fuel for my shindiawa 575 chainsaw
Re-fill with fresh fuel of the correct mixture
(Shindaiwa Premium 2-cycle Engine Oil
and gasoline-40 : 1 ratio;
other brands-25 : 1 ratio).
Workshop manual
http://www.golftechs.us/Manuals/shin%20chainsaw_current.pdf
Dec 12, 2016 | Garden
I need a carb kit installation guide for my Shindaiwa n452 hedge trimmer
There is no guide. Post the model and manufacturer of te carburetor itself. Walbro, zama, tk, etc.
Sep 20, 2013 | Shindaiwa N452
Machine starts but will not rev past idle and stops
It sounds like a clogged gas filter.
Sep 03, 2013 | Shindaiwa N452
Oil to gas ratio for a T260 shindaiwa weedeater
You will not go wrong at 25.1 fuel oil mix.
Mar 07, 2012 | General Garden
Do you use 2 cycle or 4cycle oil for mix in shindawai blowers
Not knowing what model blower you have, I do know that Shindaiwa manufactured both two cycle and 4 cycle blowers. In either case, you run the required 50:1 ratio. I would also recommend using the Shindaiwa branded oil since it is formulated to run in their equipment at that ratio.
Other manufacturers have 4 stroke blowers on the market that run "straight" fuel because they have an oil sump for the engine oil, much like a 4 stroke lawnmower. However, that is not the case with Shindaiwa's 4 cycle design which still runs "mixed" fuel.
Feb 20, 2011 | Echo Back Pack Blower Rack Fits Stihl...
FUEL MIX
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 05, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Fuel oil mix for a Poulan 14" saw ?
Oil Mix Ratio:
Sep 02, 2010 | Garden
What kind of gas/oil mix does this use
Oil Mix Ratio:
Lou
Aug 29, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Oil to gas mix
Oil Mix Ratio:
Lou
Aug 10, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Fuel mix ratio for poulan counter vibe 3400 chain saw and for a homelite st-145 weed trimmer
Oil Mix Ratio: (last 5-10 years)
If me I would have the Poulan tweaked to run properly on 50:1 and use that in both. It will start easier and take much longer to carbon foul.
Lou
Apr 30, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Shindaiwa N452 Logo
70 people viewed this question
Top Shindaiwa Garden Experts
Dennis Key
Dennis Key
john h
Are you a Shindaiwa Garden Expert? Answer questions, earn points and help others
