Question about Panasonic UF-5500 Panafax UF-5500 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop
Error code 420 - Panasonic UF-5500 Panafax UF-5500 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop
What is the problem and solution to error code 420 or 321
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
May 15, 2014 | HP OfficeJet D135 All-In-One InkJet...
Xps 420 start up problems error codes 1 and 3
Dean Fowler,
The 1-3 error code that you are saying that your computer is making represents a Video Memory Test failure. Try reseatting the video card in your computer or replace the video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 29, 2013 | Dell XPS 420 Desktop Computer
How do you fix error code 420 on an imac
You don't. The error code is nothing to do with your iMac - that should be obvious as you get it on different computers, therefore chanmging your browser will have absolutely no effect what-so-ever. The code is being delivered by the web-server you are connecting to - probably AOL
May 16, 2012 | Apple MacBook Air
Error code 1 on schwinn elliptical 420
Dear Sir:
adjust the speed sensor see the diagram attached.
2) the main board can be faulty.
3) Run the software calibration.
5_3_2012_12_02_47_am.gif sincerely. God bless you
Apr 30, 2012 | Schwinn 420 Elliptical Trainer
EROR 420
The error that you are receiving means that the machine goes to receiving mode, but receives no command from the transmitting side. The problem is not with your machine, but from the party sending you the fax.
1. Remote side mis-dial.
2. Check with the other party.
Apr 11, 2012 | Office Equipment & Supplies
HTTP 420 error; access AOL mail
What device are you trying to use to get you mail.aol.com? HTTP 420 is not a standard http error code it's probably some custom code.
If your using a smartphone, try clearing your cache and cookies in your mobile browser. If that doesn't work try disabling java script.
Comment with further details if needed.
Aug 02, 2011 | Lands Phones
Bizhub 420 error code c-2801
konica minolta bizhub 420
error code 2801 plesce relese the code prectical met
Feb 08, 2010 | Konica Minolta Office Equipment & Supplies
Hi I bought my fine drive 400 in Ebay. error code: 420-01-0x08
this may be due to corrupted firmware, I have posted the files to fix this:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
Feb 13, 2008 | Fine Digital FineDrive 400 GPS Receiver
Panasonic UF-5500 Panafax UF-5500 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Logo
83 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
