Question about Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp
Blades will not turn on lawn mower - Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp
    Sergeant:
    Champion:
  • 320 Answers
You haven't given enough information of the problem. The blades themselves wont turn when you try to spin them by hand or they wont turn when you engage them with the lever or the switch?
Posted on Nov 10, 2013
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Lawnmower blade wont turn
Probably bent the shaft. Disconnect the spark plug to prevent accidental starting and lay the lawn mower on its side. Slowly turn the blade with your hand and watch the center of the shaft. If it wobbles at all it is bent. $150 to $200 job. Probably time for a new mower.
Mar 09, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
Which way do you turn the bolt on the blades of an ariens riding mower
You turn the bolt in the opposite direction on the the way the blades spin.
Jan 26, 2013 | Ariens 42" Riding Lawn Mower Blade ...
What holds mulching blade to lawnmower?
A nut.
Unplug the spark plug.Lift the mower.Under the mower you will see the blade.It is held on buy the nut in the center of the blade.Wear a leather glove(or something similar)to hold the blade and turn the wrench(socket&ratchet)with the other hand.
Jul 12, 2011 | Arnold Corporation Arnold 21-Inch...
How do i replace blade on mountfield princess lawn mower. is it a left or righhand thread
It should be a standard thread. You may need to put a shop rag into the spark plug hole to make sure the engine does not turn while you are trying to remove the blade.
Mar 28, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
Aug 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
Mar 03, 2009 | Electric Lawn Mower
Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp Logo
233 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
