Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Tecumseh HM80-What length of pull rope do I use for replacement & where should the choke lever be set once the engine warms up, all the way to the right or on the first bump (detant?)?
    Top Expert:
  • Tecumseh Master
  • 42,546 Answers
The replacement pull rope for the motor will be the right length if you buy a genuine pull rope or a rope that is for your machine. The choke should be in the full open position when warm
Posted on Aug 03, 2013
3 Suggested Answers
  • 62 Answers
SOURCE: 8 hp Tecumseh HM80 won't start
plugged carb
Posted on Sep 26, 2009
  • 3 Answers
SOURCE: i cant find rings for a tecumseh hm80-155356n
40049 is the Tecumseh Part # for a Standard Ring Set, let me know if you need part #'s for OS Rings
Posted on Feb 08, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How do I start a weedeater fb25?
    Press primer bulb 6 times
    Move throttle lever to start position
    Move choke lever to full choke position
    Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
    Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
    After warming up for 10 seconds, move choke lever to run position.
    Manuallib.com has a manual for this model available for free download
    Oct 20, 2014 | Weedeater Garden
    Snow blower recoil rope broke tied back up and now will not recoil
    Unless the recoil spring is broken, then you may have neglected to pre-load the recoil spring. With the recoil unit off of the motor, wind the rope fully around the pulley. Then, while keeping the rope fully wound, turn the pulley about 5 times around in the direction that would push the hope out through the hole. At this point the recoil spring will be trying to spin. Without losing that tension, push the end of the rope out through the hole, thereby putting a bit more tension on the recoil spring. Tie on the handle. Now, when you let go of the rope, the spring should hold the handle snug against the hole. An alternative method is to use a rope about 2 to 3 feet longer than the original. Wind it fully around the spool and put the end of it through the hole. Now pull the extra length through the hole until the tension is sufficient. Cut off the extra length and tie on the handle.
    good luck, Al K
    Jan 11, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    PULLED ROPE AND HAND SLIPPED OFF NOW THE ROPE WON'T RECOIL ALL THE WAY BACK INTO ENGINE. RECOILS ABOUT HALF WAY. WHAT SHOULD I DO TO FIX THIS PROBLEM?
    Play with it ... My Tecumseh does the same. The little catches inside dont always catch like they should. You can remove it and fiddle with them like I did ... it will work for a while and go bacl the the 1/2 trick. You can replace it ... and it will be ok for a while ...
    I have learned to live with it ... my tiller is 1977 model
    Oct 26, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    Need to replace the recoil rope and handle on a tecumseh hm80 155481 p 8hp horazontal shaft motor. never done one before so any suggestions would be great
    take the 4 bolt out of the starter housing, lay on table take the old rope out. turn the center rope pulley counter clock 6 to 7 full rotation's so the center pulley hole lines up with out housing hole(steck a screw drive throw to hold pulley in places). feed the rope from outer throw the center tie off. let the pulley dr ow the rope in. pull the rope out a Little tie off to handle
    Oct 08, 2009 | Yard Machines Heavy Machinery
    Recoil rope won't recoil!
    -In bnjays case the rope was broken. Sometimes the rope retracks partially or slowly because the surface that the spring edges rub against when retracting the cord, are badly rusted. Disassemble and wire brush the rust off, or leave assembled and spray in thru holes in the pull start with WD40.Avoid getting WD40 on the rope.
    Feb 18, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    Rope snapped in my recoil starter..
    take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
    Jan 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
    Top Tecumseh Tools & Hardware - Others Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    ArcFlash
    Level 1 Expert
    JonSnell Electronic
    JonSnell Electronic
    Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
