My Panasonic viera plasma cuts off part of the picture to every show and I've tried the aspect button and nothing works
I had this problem and it turned out to be the mother board in my case.
Posted on Jan 11, 2013
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
The picture on my 42"
SHOULD BE A BUTTON ON THE PANASONIC REMOTE THAT SAYS "FORMAT" OR "SIZE" OR "WIDE" OR "ASPECT" PRESS THAT BUTTON UNTIL DESIRED PICTURE IS ACHCEIVED.
Dec 17, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
The direct tv menu guide is cut off around the edges...how do i fix?
Your TV resolution is not set to the proper screen size for viewing it properly and it probably cuts off your tv shows too and you just don't see it. Press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
Nov 04, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Hi our panasonic viera has a very large picture that does not fit into the frame of the TV. Normal option under picture isn't available and zoom isn't working either is aspect
hi hust a tip hope it would work, try to adjust the aspect ratio, if not check if ther is a zoom button on the remote that can actually adjust the size of the picture but normally adjusting the aspect ratio will solve the problem. hope this would work, goodluck!!!
Jun 03, 2010 | Panasonic Viera TH-42PX80U Plasma TV
What setting do i need to have my tv on for a game system? Panasonic viera plasma tv. I believe it is a 40"
There is no specific setting that is "required" to be on for a game system, there is a built in mode label game mode, Press the aspect button on the remote, this mode make the picture a bit darker, which will keep any type of static logo from retaining on the screen, if image retention occurs, the logo will fade over time, would have to be stationary on the screen for a few weeks to become permanent.
Jul 18, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
