Vizio tv gets only blue screen
Tv powers on gets blue screen control panel will not work for anything cant turn off volume dont work channels wont work no picture
  • 8,617 Answers
The main board needs replacement very common issue. You can get a replacement main board from www.tvrepairworld.com
Posted on Jan 11, 2013
  • 479 Answers
SOURCE: lcd tv screen turned black and i cant get any picture
its the problem of blown capacitors on rthe main board just check out the faulty ones with the help of multimeter and get it replaced.
Posted on Dec 10, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
  • 18 Answers
SOURCE: No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Posted on Apr 03, 2010
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
Vur9 remote only controls the volume and nothing else, cant change channels or anything any suggestions?
Press the TV button on the lower right (not the upper right) to tell the remote to control the TV.
The upper buttons are the Input Selector buttons. The lower buttons are the Device Control Selector buttons.
I had this same problem until this dawned on me.
Apr 20, 2009 | Vizio VO47L 47 in. LCD TV
Turns on .encripted channel comes up. cant switch channels
threw the damn thing in the trash. will never buy another ilo tv. this is the replacement for the first set that quit working. thank you
Feb 18, 2009 | iLO 2600 Television
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
Tv screen went blank
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
